control box humming and no water
snowman10200
Victoria, TX
I have a Red Jacket Control Box that is humming and the 3/4 hp pump is not pumping water on the submersible pump. no pressure on system so I assume the pump is not running,
What are some things I can check to get water back to the house
LLigetfa
DIYer, not in the trades
NW Ontario, Canada
You could check voltage, current, and ohms resistance to diagnose the pump. You could check the relay and cap or caps in the control box.
Valveman
Cary Austin
cyclestopvalves.com
I would check to make sure I had 240 volts coming from the pressure switch. If that is correct I would just try a new control box. If you have the correct voltage and it still clicks and buzzes with a new control box, you have probably already cycled that motor to death.
DonL
Houston, TX
You should take a look in the control box to see what is humming.
The start cap could be bad and may cause the relay to chatter or hum.
It is not good for the motor.
Good Luck.
