Results 1 to 5 of 5
Thread: Bladder tank and holding tank
    DIY Junior Member Jtbartlett's Avatar
    Sep 2013
    VT
    Default Bladder tank and holding tank
    I am in the process of plumbing up a new house. All DIY and I'm not a professional. I recently set a 7gpm goulds pump at 480'. Plenty of water at 1 gpm recovery rate. This is an off grid house so I'm trying to run the pump as infrequently as possible. Young family of 4. I have a 36 gallon pressure tank and would like to run two tanks in series. My question is whether I need to run 2 bladder tanks or can I run the 36 gal into another, larger batch tank, or non-bladder water tank. I have a 40/60 pressure switch. As long as the second tank can hold the water pressure can I do this? I'm not looking for real high water pressure. Tanks are on the second floor, kitchen immediately below tanks, 1 bath upstairs with shower, 1/2 bath downstairs. I have no problem plumbing 2 bladder tanks in series but if I can get the extra capacity with a larger batch tank I'd like to do that instead. Hopefully I've given enough info. Thanks.
    In the Trades Texas Wellman's Avatar
    Feb 2010
    SE Texas-Coastal
    What is your power source? I may have a better solution for you.
    Sep 2013
    VT
    Quote Originally Posted by Texas Wellman View Post
    I'll have 240vac from a DC inverter. I should say I'm not really concerned about the power used, rather, I'm trying to limit the frequency of the well pump. Ideally I'd like to fill the tanks in the morning, and possibly again at night. I'd prefer not to have the pump cut in and potentially overload the inverter if something else happens to be running simultaneously. I was thinking I could possibly add a tank after a checkvalve and plumb a manifold from the batch tank to the downstairs. I am guessing the drawdown is going to be equal through both tanks and it probably won't work.
    Moderator valveman's Avatar
    Mar 2006
    If you plumb them close together and don’t have really small pipe between them, multiple tanks will fill and drain at the same time.
    At 40/60 pressure, a 36 gallon tank only holds 9 gallons of water. An 80 gallon tank would hold 23 gallons.
    But if you only put in 20 PSI air charge and let the pump fill them to 60 PSI, you can get 18 gallons from a 36 gallon tank and 46 gallons from an 80 gallon tank. The outlet pressure will vary widely from 60 to 20 PSI, but that way you get the most draw down from a bladder tank.
    Feb 2011
    NW Ontario, Canada
    Depending on the quality and design of the bladder, undercharging it could cause it to stretch and shorten the life. Some bladders just roll back and forth, like turning a sock inside out and outside in.
  1. make bladder a holding tank?
    By jeeper1 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-20-2012, 08:12 PM
  2. Tank air pressure for non bladder water tank
    By DonL in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-05-2012, 10:56 AM
  3. Holding Tank Setup
    By milkman1 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-21-2009, 07:19 PM
  4. Why Galvanized Tank and Bladder Tank?
    By dyoungers in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-09-2007, 08:17 AM
  5. how can I get the holding tank to work with the well?
    By lories in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-13-2006, 08:32 AM
