Page 1 of 2 12 LastLast
Results 1 to 15 of 19
Thread: Choosing Electric Space Heater for Emergency.
    DIY Senior Member molo's Avatar
    Sep 2006
    cold new york
    Default Choosing Electric Space Heater for Emergency.
    Hello,
    I know that electric space heaters are sometimes the cause of electrical problems (breakers/fuses tripping, parts of the circuit overheating, heater overheating because of poor design/materials, etc). However, I am trying to select heaters to use while we wait for service in the event that the primary heat source goes out.
    1. How should I size the heater to be sure that it won't overheat the circuit or trip breakers?
    2. Are there any brands that are know to be good or bad?
    Thanks in advance!
    "Any American who is prepared to run for President should automatically, by definition, be disqualified from ever doing so."
    Gore Vidal.
    DIY Junior Member Glennsparky's Avatar
    Oct 2012
    Oviedo, FL near Orlando
    Quote Originally Posted by molo View Post
    For 120V circuits, 1440 Watts will max out a 15A breaker. 1920 Watts will max out a 20A breaker.
    You have to add up the heater watts and the watts of anything else plugged into that circuit.
    Jun 2007
    NY State, USA
    Quote Originally Posted by Glennsparky View Post
    This is not true at all. Why do folks insist on perpetuating this MYTH???
    1800 for 15A. 2400 for 20A.
    Continuous loads follow certain rules for circuit loading. A portable space heater is not considered a continuous load.
    I am no fan of space heaters. They cause more problems and fires than I care to know, but come on, facts are facts.
    Mar 2011
    Houston, TX
    I like the cheap Walmart Lakewood.
    They are small and have a 750W and a 1500W setting.
    I have a few in use and always use the 750 Watt setting.
    1500 Watts is not safe for long periods.
    Have Fun.
    Mar 2011
    Long Island, NY
    Have Fun.
    Long periods are not safe, and never fun. Sorry Don, had to say that.
    In the trades Dana's Avatar
    Jan 2009
    The little oil filled finned radiator types (DeLongi, and others) are quieter and safer from a fire-hazard point of than anything with a blower or radiant-reflector. Many/most come with dual elements a 600W and a 900W separately swichable, so you can have it pulling only 600W OR 900W if you don't think the circuit can handle 1500W), and an adjustable on-board thermostat to limit the surface temp of the unit. Shop around, and can usually find a pretty good one for under $50.
    Sep 2013
    While they are not space heaters, infrared heaters can make you more comfortable for fewer watts. The infrared produced turns to heat when it hits your skin or clothes (or anything else). So if it points to your sitting position, you can be comfortable with a lower air temperature. They will still heat the room as as well as a regular heater for a given power, but the infrared will make you feel warmer for the same watts.
    Sprinkler Guy Wet_Boots's Avatar
    Mar 2007
    Metro NYC
    the Pelonis Disc Heaters were always touted for their safety, being that their thermistor heating elements never got fire-starting hot
    Mar 2011
    Houston, TX
    Quote Originally Posted by Speedy Petey View Post
    Why do you need to confuse things with the facts ?
    People do operate them at 100% load when they get cold.
    Mar 2007
    Metro NYC
    It is kinda interesting/significant that these things seem to max out at 1500 watts, which is just a hair away from 80 percent of a 15 amp load.
    Oct 2012
    Thank You, DonL.
    Jun 2007
    NY State, USA
    What's confusing?
    And what does "100% load" have to do with it?
    Jun 2007
    NY State, USA
    Please tell me where I can find this in the NEC. Thanks.
    Mar 2011
    Houston, TX
    What's confusing?
    Nothing really.
    You are correct for the circuit being able to handle the load. The Line cord and plug won't last long.
    My 100% was about how people Put the heater on High, Blow and Go 100 percent of the time.
    Just because a Microwave Oven has 100% Power does not mean that you need to use it. Popcorn requires 100%.
    900 Watts is a good Max for what may be operating at 100 percent duty cycle and most likely is unsupervised.
    Just make sure to install a Smoke Detector near the heater and have 911 in quick dial to operate the 1500 Watt mode.
    Oct 2012
    Since the OP said "emergency" and "primary heat" failure, I could only imagine that the space heaters would be on the highest setting all night. Then I thought about how many back stabs the circuit might have gone through. As such, I only felt comfortable with numbers that reflected all loads being continuous.
    I admit to cowardice and cutting corners on my answer and I throw myself on the mercy of the court.
    But I still side with DonL's posts.
  1. Need help choosing a water heater
    By jestyr in forum Water Heater Forum, Tanks
    Last Post: 04-17-2013, 05:42 PM
  2. Power Out From Electric Space Heater
    By Kiko in forum Electrical Forum discussion & Blog
    Last Post: 01-31-2013, 01:03 PM
  3. Safer: Electric Space Heater Or Bathroom Heater/Exhaust Vent
    By Briandl in forum Shower & bathtub Forum & Blog
    Last Post: 02-15-2011, 12:40 PM
  4. Choosing a water heater
    By CarlH in forum Water Heater Forum, Tanks
    Last Post: 02-06-2009, 06:20 PM
  5. Toilets with space for an electric baseboard
    By Perfectionist in forum Toilet Forum discussions
    Last Post: 04-07-2007, 04:31 AM
