Results 1 to 10 of 10
Thread: local terms
    Plumber jimbo's Avatar
    Default local terms
    A recent post about "spigot" fittings got me to thinking about a lot of plumbing terms which seem to be local to a certain geographical area:
    Desanco fitting
    Marvel connector
    Smitty plate
    LA pattern trap
    Dresser coupling
    "tap" vs. "faucet"
    anybody add to the list?
    Apr 2005
    The tube coming off a water heater T&P valve, drip leg.
    Default term
    It is only a drip leg when the valve malfunctions. Normally it is the T&P discharge pipe. Drip leg is the capped extension below the tee where the appliance connects.
    Around here you can always tell the locals because they say "street elbow".The guys from out of town say "service elbow".
    Plumber Cass's Avatar
    Is the capped portion of a gas T called a dirt leg OR drip leg? I have heared it called both. I have always called it a dirt leg.
    Feb 2005
    Talking both
    I have heard the called both.....dirt legs and drip legs...
    to catch either moisture or dirt chops, I guess.
    now have you ever heard of a shovel being called a "dummey stick"
    Yes, a dummy stick, and I still use one from time to time.
    How about a mattock being called a grub hoe?
    Feb 2005
    Talking when a hoe was just a hoe.....
    remember when a hoe mean only a hoe??
    now it can mean a slang terms you call some ladies.
    Default Term
    A shovel is sometimes called a "banjo pump" when you need to remove water from the ditch.
    Default term
    You are confusing "hoes" with "ho's".
