Results 1 to 2 of 2
Thread: Quick Question - Two baseboard Tstat's on Same Circuit
    Default Quick Question - Two baseboard Tstat's on Same Circuit
    Hello,
    I am adding a new 240v circuit to supply heat to my garage (1500w) and a powder room (500w) directly adjacent.
    Given the layout, I would like to run a wire from the panel to a junction box, and then run a seperate wire from the j-box to each room with it's own thermostat/heater. Within the J-box i would connect all 3 red ends together and all 3 black ends together.
    My intention is to use 14/2 wire and a 15 amp breaker.
    Does this sound safe and correct? Any advice would be greatly appreciated.
    Patrick
    Jun 2007
    North Carolina
    sounds good be sure to use four wire thermostats
  1. Quick Question about No-Hub
    By glnow in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-09-2011, 04:39 AM
  2. Quick question on glass framed pivoting shower door hardware question
    By watson524 in forum Shower & bathtub Forum & Blog
    Last Post: 02-09-2011, 05:38 PM
  3. changing heat only tstat to heat and cool tstat
    By pipe bender in forum HVAC Heating & Cooling
    Last Post: 05-09-2010, 06:35 AM
  4. Quick Question
    By akantler in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-26-2010, 08:35 PM
  5. Tstat Common Wire
    By PTN in forum HVAC Heating & Cooling
    Last Post: 11-12-2007, 09:04 AM
