Results 1 to 10 of 10
Thread: Lower kitchen drain to line up for new p-trap
    DIY Junior Member in need of help's Avatar
    Nov 2013
    Alberta
    Default Lower kitchen drain to line up for new p-trap
    I have attached photos:
    I need to lower the drain so that i can install a normal p-trap for the kitchen sink plumbing. My house was built in 1958 and majority of the plumbing is original. What tools should i be using to cut this pipe and attach p-trap? I realize i will need to cut the cabinet walls that is encasing the drain, nit a problem. But i dont know what to purchase to attach the p-trap (which i still need to buy) to the drain. Also what do i need to do to the drain to lower it? Im in
    experienced but capable of learning and following instructions. Please any help that can be offered is appreciated.
    Thank you
    Nov 2010
    Maine
    If it was me I would chase that old galvy back to the cast iron source and replace it all with PVC. You can cut what you have there with a metal blade in a sawzall but all the viberation will most likely cause leaks further down the line and I'd bet the old galvanized steel is pretty much rusted up.
    That may give you the option of going with 2" up to the santee too.
    That galvanized is going to be a lot tougher than Tom Sawyer thinks. What is that big cavity you are taking the pictures in, and if the pictures are sideways, what is the "checkerboard" material to the right of the tee, which should be between the tee and the floor?
    DIY Senior Member Reach4's Avatar
    Sep 2013
    I think the plaid picture is left-up. I think that is the other side of the right of the colorful picture. And I think that is being lit by a candle that is being held. So the plaid would be the floor of that space.
    You should be able to cut the 1.5" pipe with a sawzall and install a new santee there using no-hub couplings.
    DIY Junior Member 6t7gto's Avatar
    Jan 2010
    Bedford, Ohio
    I'm guessing the plaid covering is a shelf in the adjacent cabinet.
    Nov 2010
    Maine
    All in a days work HJ. Its what I get the big bucks for LOL
    some people say I get even bigger bucks.
    Nov 2013
    Alberta
    Reach4 and 6t7gto are correct. I think i will pay a professional to replace the drain just incase tom sawyer is correct about the rusting. Thank u all for ur suggestions. Love this site!
  1. Add a drain line for a kitchen sink to an existing drain line for a washing machine?
    By Loflow in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-25-2011, 05:49 AM
  2. Lower kitchen drain for disposal - should I give up?
    By mo51 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-30-2009, 08:04 AM
  3. kitchen sink drain is lower than waste pipe and leaks
    By lafk in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-08-2007, 10:55 AM
  4. P-Trap Lower than Drain Pipe
    By rayleeis in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-16-2006, 08:09 PM
  5. New sink is lower...need to lower drain?
    By plumbbob in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-07-2004, 02:23 PM
