Results 1 to 6 of 6
Thread: American Standard 2 handle faucet HAMPTON model with rough in kit
    DIY Junior Member JHenry6941's Avatar
    Nov 2013
    Alabama
    Question American Standard 2 handle faucet HAMPTON model with rough in kit
    I have a walk in shower with thick ceramic tile (House built in 60s) and a joist(load Bearing): that will not let the faucet go through the wall enough to connect handles///so I called American Standard they told me I needed a rough in extender kit which I ordered...and my plumber says its still not long enough...can anyone help me?..What I need is an OLD Style faucet built for a 60s home basically...Any ideas/thoughts or whatever would be appreciated..(I don't know why my plumber cant figure something out!)
    http://www.americanstandard-us.com/a...cSheet_535.pdf
    It looks like you have some room between the wall and the pipes. Is he just concerned about lining up with the previous pipes in the wall?
    Why would a joist, which should be under the floor, have anything to do with how the faucet is positioned in the wall? How is he managing to make it pressure balanced as required by ALL codes now?
    DIY Junior Member robert13084's Avatar
    Nov 2013
    waco, TX
    Pfister makes a 2 and 3 handle faucet with longer stems. If thats not long enough pfister also makes stem extension up to 2".
    Nov 2013
    Alabama
    Exclamation Answer
    Sorry Im no carpenter either...I guess the proper term would be studs? At any rate I ordered the American Standard model7221.732.002 Polished Chrome from..Hope it works will let u guys know thanks for the ideas one more thing according to the leterature That was sent to me this faucet meets code
    That valve has "construction and material code" approval and "ADA approved HANDLES", but it does not indicate, nor do I know how it could be, "temperature/pressure regulated as is REQUIRED for ALL shower valves.
  1. American Standard two handle tub valve
    By jm66208 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-16-2013, 07:44 PM
  2. American Standard model ID?
    By LocalHero in forum Toilet Forum discussions
    Last Post: 03-10-2010, 07:13 AM
  3. American Standard Cadet Model 1674/1675
    By jondak4x4 in forum Shower & bathtub Forum & Blog
    Last Post: 06-07-2009, 07:49 PM
  4. American Standard K73 model.
    By grazzy in forum Toilet Forum discussions
    Last Post: 11-04-2007, 01:14 PM
  5. Leaking American Standard single handle shower faucet
    By VT Pats Fan in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-20-2006, 01:24 PM
