Brass Nipples vs. copper w/ sweated NPT fittings?
Speede541
Oakland
Once we're into the longer lengths of brass nipples for faucet connections, does it make more sense to just use copper pipe with NPT fittings sweated to the ends?
Or is over-stressing the sweated connection in the wall (copper pipe to NPT fitting, threading into the drop ear) too big a risk?
I'm needing brass nipples in the 9 to 10" range, which are easy enough to find, but it seems more practical to simply cut pipe to the length needed.
Long term, it could be a problem if the male adapters "seize" into the elbows and the copper twists in two instead of unscrewing. I prefer the rigidity of brass, even if I have to use two shorter nipples and a coupling.
