Results 1 to 9 of 9
Thread: do AAVs expel sewer gases?
    DIY Member pronouncedeyen's Avatar
    Sep 2009
    Baltimore, MD
    Default do AAVs expel sewer gases?
    This may be a stupid question but if an AAV remains closed until it receives negative pressure from water going down the drain then how does it expel sewer gases? What happens to them if you use an AAV?
    DIY Senior Member Reach4's Avatar
    Sep 2013
    A properly-operating AAV only admits air. Sewer gases will make it out of the sewer after or during the sewage passage. Eventually it will go by a vent.
    An AAV needs a proper vent somewhere in system for postive pressure. There should be at least one vent through the roof for that.
    Only when they fail...
    I question item E, because there is no way to "engineer design" the installation to vent trapped air in an ejector pit if there is no "atmospheric vent" and/or the water in the pit rises above the inlet piping.
    Nov 2010
    Maine
    Well now HJ, if you log on to the Studor web site you can find an engineered drawing for just such a thing. Of course, as you look at it you will note that the way they have the AAV installed it pretty much does nothing. LOL
    I think most of the plumbers would refuse to use them on a pumped system.
    I remember on one basement installation where I went to the next floor and used the 2" toilet vent.
    DIY Senior Member asktom's Avatar
    Nov 2009
    Victor, MT
    AAVs are lazy plumbing. They will eventually fail, no matter how the Studor folks frame it. AAVs are from the "wham bam thank you mam" school. Gravity, which includes atmospheric pressure, will continue to work indefinitly. Vent it right and it is a done deal.
    Nov 2010
    Maine
    Honestly, other than an island sink and even there I'd rather waste stack vent, I have never in near 40 years of plumbing installed one and never will. I have always been able to find a way to properly vent the fixture and if the homeowner doesn't want the expense or possibility of having to do sheet rock repairs, I walk away from the job. Not interested in hack work and better than that, I don't need it either. Then again I feel the same way about PEX, flexible supply tubes and plastic J hook hangers. We don't stock any of the above, don't use any of the above and I would probably fire any plumber working for me that did. Add CSST for gas piping to the list LOL
  1. Connecting Collapsed Storm Sewer to Sanitary Sewer?
    By amkjud in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-30-2013, 07:02 AM
  2. Connecting Hot Water Heater Drain Pan to Sewer - Will Swing Check stop sewer gas?
    By Jim109 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-21-2011, 12:43 PM
  3. Pros and Cons of Using AAVs
    By dondiy in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-18-2007, 05:22 AM
  4. Why do I need vents? (How about AAVs?)
    By talkingdog in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-28-2007, 08:50 PM
  5. Sewer line to city line (sewer lateral) question r/o
    By H20Melon in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-11-2005, 05:12 AM
