Results 1 to 6 of 6
Thread: Arlington, Texas - Kitchen sink / disposal drain configuration - Compliant?
    DIY Junior Member Desmo749's Avatar
    Nov 2013
    Arlington, TX
    Default Arlington, Texas - Kitchen sink / disposal drain configuration - Compliant?
    Hi all - I have searched the forums and various threads but was unable to find anything that addressed my configuration specifically.
    I have had both configurations under my sink and both have worked (did not leak and drainage was very good) however I would like to be code compliant. I am a DIYer.
    Funky but compliant
    Not compliant. You have created an S trap that will siphon.
    There is an air gap installed on top of the counter where the drain hose from the dishwasher connects to the sink drain (disposal). The continuous waste pipe from the disposal to the T slopes downward from left (disposal) to right (T). In the top image, the horizontal waste pipe from the T to the elbow and ultimately to the P-Trap slopes downward from right to left (towards the P-trap). In the bottom image, the horizontal waste pipe FROM the elbow to the trap arm slopes downward (right to left).
    Is there a better way to do this and are either of these configurations code complaint? Is it okay to have the trap arm from the wall facing up as opposed to down?
    Any advice/recommendation provided would be greatly appreciated.
    Thanks.
    It would be better to go with the top pictue, but a 45 from the wall to the vertical drain below the tee.
    Nov 2013
    Arlington, TX
    Thanks Terry - A 45 from the wall? I am not sure I know what that is, I will do some searching but if you have a picture or link to one that would be great.
    Thanks again.
    Nov 2013
    Arlington, TX
    Okay - would the 45 be pointing to the side (toward the vertical drain below the T) or down? Having a tough time visualizing this. Will the 45 allow me to move the p-trap directly under the T? Is that the objective?
    Nov 2013
    Arlington, TX
    Would the image on the right be a better option as my main drain from the wall is so low?Name:  disposalwastekit.jpg
    We aim the trap arm toward the drain we are connecting. A 45 is half of a 90 bend. A full circle is 360.
    I don't like using a tee in the middle, though we do it that way too.
  1. Does this sink drain configuration look right?
    By lojoma in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-13-2012, 08:34 PM
  2. Drain Pipe too high (kitchen sink) for disposal
    By BillN in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-27-2009, 12:53 PM
  3. Kitchen Sink -- disposal hookup, drain miscalculation
    By remodelbob in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-07-2008, 08:35 PM
  4. Kitchen sink drain (in wall) and disposal output!
    By mad1ben2 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-13-2006, 08:57 AM
  5. kitchen sink disposal
    By mjrva in forum Remodel Forum & Blog
    Last Post: 06-02-2005, 06:06 AM
