Thread: HIGH Iron in Manganese in well water! Recommendations?
    Default HIGH Iron in Manganese in well water! Recommendations?
    Hi there,
    I am in the process of buying some land and just saw the water test results:
    Hardness < 33 mg/L
    Iron 26 mg/L
    Manganese 0.47 mg/L
    pH 7.27
    TDD 72 mg/L
    Turbidity 200 NTU
    Are there any solutions for such high Iron and Manganese? Any idea of capital cost & maintenance costs? The water came out of the pipe cloudy and yellow and red flakes are settling at the bottom of the sample I took. It seems to be clearing up over time.
    Sep 2013
    I am confident there would be a solution. Maybe $1200 or $2000 for a filter installed. I sent a message of what I would be thinking, but others may have better ideas.
    If you have flakes, that would probably be from the pipes. That could be filtered out, and/or you might need to have pipes replaced. Figure 1 or 2 Big Blue filters at roughly $100 each for flakes and sediment.
    These are my guesses. I am not a pro.
    Moderator valveman's Avatar
    Mar 2006
    You might check into the Sulfur Eliminator to get rid of the iron by aerating the water in the well. Then it might not take much of a filter to collect the larger stuff.
  1. SST-60 Resin, Reducing salt, removing manganese and iron
    By cgarai in forum Water Softener Forum, problems, installation and reviews
    Last Post: 05-26-2012, 08:03 PM
  2. Need suggestions regarding Systems for Iron and Manganese Problem in Well Water.
    By BillF in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-12-2012, 10:11 AM
  3. Very Hard Water and High Iron
    By williamsjan in forum Water Softener Forum, problems, installation and reviews
    Last Post: 08-29-2010, 04:18 PM
  4. High iron in water questions.
    By KingDaddy in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-01-2009, 10:59 AM
  5. High iron level in well water
    By Roadtrash in forum Pumps and Tanks Well Forum & Blog
    Last Post: 11-25-2008, 10:47 AM
