Results 1 to 13 of 13
Thread: Burying a water line
    DIY Junior Member dripdrip's Avatar
    Nov 2008
    NE
    Default Burying a water line
    Hi. I'm burying a water line between buildings. I'm hoping to use polyethylene, and was told to surround it with sand by a plumber. (Yes, I'm going below the frost line.)
    Can I sleeve it in schedule 40 PVC *instead* of using the sand?
    DD
    DIY Senior Member craigpump's Avatar
    Apr 2012
    ct
    Yep, we do it all the time using 4" sch 40 for the sleeve
    The one I did a couple of days ago was surrounded by "dirt".
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by dripdrip View Post
    ...was told to surround it with sand by a plumber.
    Why would you avoid using sand around the pipe? You don't need to use a plumber to shovel sand. Any DIY'er can do it. You don't need a truckload of sand. You can pick up a few bags of sand at most any big box store.
    Master Plumber Caduceus's Avatar
    Oct 2013
    Pittsburgh, PA
    It's always advisable to 'snake' HDPE or PEX water services in the ditch, y'know kinda side to side like a snake (not snake like a sewer snake). This allows for expansion and contraction of the pipe. In my area we don't sleeve with pvc except for the last 10 feet or less before entering the home and any sleeving in the ditch is done with the next larger size of HDPE so that there is some giving when expansion/contraction occurs.
    DIY Senior Member dj2's Avatar
    Aug 2013
    California
    Another vote for sand.
    Oct 2013
    Pittsburgh, PA
    Yeah, I left that out of my last post. I would just do sand, too. Best protective fill for plastic pipe. You could even run a locator (copper) wire in the ditch in case you need to find it in the future.
    Nov 2008
    NE
    Well it's about a 100 foot run, and the backhoe bucket is 16" wide. So roughly how much sand would I need? Does it just need a little all the way around the pipe?
    Aug 2013
    California
    Good thing that you asked!
    The pipe should have 2-3 in under it and 2-3 in around it. The rest can be dirt.
    Mar 2011
    Houston, TX
    Don't go 16 inches wide, save sand.
    Using bag sand is a bit if a joke.
    Get a load delivered.
    Good Luck on your project.
    About 2 cubic yards or a bunch of bags, neither of which are "cheap".
    Feb 2011
    NW Ontario, Canada
    Well... that was before I knew it was a 100 foot long trench a foot and a half wide. I don't know how deep the frostline is in NE, but I assumed a trencher cutting a 3 inch wide trench.
    That's not to say you cannot make a narrow trench in the bottom of that mammoth one. One has to wonder what the existing material is and just how hostile it might be to the pipe.
    I either use the "hostile" dirt, or let the customer furnish, and place, the sand, then backfill the trench.
  1. Cappping & Burying Water Pipes in Basement
    By stingme in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-10-2013, 03:46 PM
  2. Burying sump pump line to storm sewer
    By mikeydiker in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-04-2011, 05:51 PM
  3. Burying Copper Pipe
    By dgale in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-06-2011, 10:24 AM
  4. Burying line for sump pump
    By cacher_chick in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-12-2008, 06:52 PM
  5. Best drainage pipe to use for burying down spouts
    By marc5688 in forum Lawn Care/Landscaping
    Last Post: 06-28-2007, 01:12 PM
