Results 1 to 5 of 5
Thread: white build up around taps
    DIY Junior Member K Paterson's Avatar
    Nov 2009
    Ontario
    Default white build up around taps
    I had a very very old water softener using alot of salt. It finally broke. I replaced it with a Fleck 5600SXT. After having it installed professionally and using it for a year I continue to get a white (assume calcium) build up on my taps. Here are the settings for the Fleck. I currently use Culligan Salt. All functions seem to work, I am hoping it is just a settings issue. Please help.
    Single Tank
    C: 24.0 x1000
    H: 79 (my hardness is closer to 70)
    RS: SF
    SF: 0
    RC:0
    DO: 3 (prefer just to regen every 3 days)
    RT: 2:00am
    BD: 60
    BF: 11 ( was 8 2mths ago, changed hoping to improve on problem)
    BW: 13
    RR: 13
    BLFC size is 0.5GPM
    Nov 2009
    Ontario
    Sorry late update: 2 months ago I had my water tested and was told I had a -1 ion, so I bumped my BF to 11, previousy 8, but still same problem. Thanks
    DIY Senior Member lifespeed's Avatar
    Apr 2007
    California
    Post your water test results.
    Lifespeed
    DIY Junior Member Noyzee1's Avatar
    Sep 2013
    SoAz
    Quote Originally Posted by K Paterson View Post
    Is it possible that the white buildup is now sodium instead of calcium chloride or magnesium chloride? You can't remove the solids via ion exchange, just convert them to sodium, AFAIK.
    Cheers,
    JIM
    Jan 2012
    California
    Sodium will leave spots, but these are almost instantly dissolve with the next use of water. There are many other factors that could be causing this. Without a detailed water report, we would only be guessing wildly.
    Technical silliness below,
    Ion Exchange is used to remove TDS. DI resin replaces the negatively and positively charged ions in the water with H+ & OH-, or water. DI resin would not normally be used in a residential application of course. I have a large DI system at my house, but this is for the carwash and is pretreated with an RO system.
  1. Replies: 3
    Last Post: 07-23-2013, 02:03 PM
  2. Tankless Water Heater white powder build up
    By cpthook in forum Tankless Water Heater Forum
    Last Post: 03-09-2013, 07:46 AM
  3. Slow well replenish rate...to build or not to build?
    By rinibean in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-10-2012, 03:48 AM
  4. Lime build up/whats best faucet brand for minimum build up ?
    By tototalitarian in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-09-2008, 02:49 PM
  5. Is Toto Colonial White similar to American Standard White?
    By MikeLane in forum Toilet Forum discussions
    Last Post: 11-13-2005, 02:24 AM
