Results 1 to 5 of 5
Thread: Toto Aquia Vs. Mansfield EcoQuantum 147-119
    Cool Toto Aquia Vs. Mansfield EcoQuantum 147-119
    I am building a new house and will be installing 3 new toilets in the next few weeks. I am only interested in Dual Flush toilets.
    I looked at the sterling and discounted it based on the MaP rating.
    Right now the two that I am seriously considering are the Toto Aquia and the Mansfield EcoQuantum, both dual flush designs.
    The Toto is a Washdown design while the Mansfield is siphon with a pressure tank.
    Caroma dual flush, Like many dual flush toilets, there isn't much water in the bowl.
    I think I really want to go with the Toto, but the cost is substantially higher, also the small water spot worries me. I have used a Caroma before and found the water spot to be way too small that it did not completely cover the waste, plus it was such a long way down that there was quite a bit of splash factor.
    Another factor is that I am on a well, and I know very little about the FlushMate system and how much water pressure it needs to affectively build up the pressure in the tank.
    I guess my questions are:
    1. Is there anyone out there that is familiar with both and can give me their impressions.
    2. Is the water spot on the Aquia better than on the Caromas? Should I even be worried about this?
    3. I thought the washdown systems needed a big Trap diameter, and I see the Aquia's trap is only 2 1/8. Should I worry about this?
    Thanks for your feedback in advance.
    -J
    Plumber jimbo's Avatar
    Check the 2006 MaP report on performance.
    The Sloan Flushmate in the Mansfield suggests I believe 40 PSI minimum. The performance will definitely be variable with a varying pressure on your well pump system.
    Hi,
    I have checked their performance on the "HIGH EFFICIENCY TOILETS" report last updated on 12/23/05.
    The performance of the Aquia and the Mansfield are very close, (800 vs. 825), so that does not help the decision making.
    Your comment about 40psi made me look a little harder and I found the following at the Flushmate website:
    What is the minimum pressure requirement for this unit?
    20 to 125psi or higher. The recommended range based on ANSI standards is 20 to 80 psi or higher.
    -J
    In the house I have a 1.0 gallon Vorten pressure assist toilet using the new Flushmate.
    I moved in two months ago, and replaced all the toilets. It had been raining in Seattle the whole time until this last week.
    I though I was listening to my rain gutter drains all this time at night, but a few days ago I noticed I could still hear the water sound, and it wasn't raining.
    I checked the toilet, and there was the noise. There is a constant leak from the cartridge. I shut off the supply and went back to sleep.
    A comment about this 1.0 gallon toilet. There is very little bowl wash at the front of the bowl. If you drop a piece of toilet paper at the front of the bowl, it may not go down.
    The dual flush Aquia in the other bathroom, has more bowl wash, and what I perceive as a quieter flush.
    Terry,
    Thanks for the info. After reading a lot of info here and other places I think I may spend just a bit more and got for the Toto.
    -J
