Results 1 to 6 of 6
Thread: Shower Valve Rough, use union or not
    DIY Senior Member diyfun's Avatar
    May 2011
    MA
    Default Shower Valve Rough, use union or not
    I just found the shower rough in I have is thread type. I would like to be solder type.
    I am a little worry about the leaking from the threaded joint after everything is there. One way to relieve this is use it with union.
    Do you think it is good idea to add an union there?
    thanks,
    You can either solder in the male adapter to the body,
    or solder a male adapter onto pipe first, dope and thread in.
    Using a union just gives you three more places it could leak.
    DIY Senior Member dj2's Avatar
    Aug 2013
    California
    Plumbers have been installing threaded and sweat for years - done correctly they both have the same durability. You don't need unions.
    Just remember to remove the cartridge if you sweat.
    May 2011
    MA
    a special adapter? I tried the 1/2" pipe. It cannot being plug into the body.
    Yakima WA
    One way to do this is to solder a piece of pipe to a 1'2" male adapter. Then screw the adapter into the valve body. Then solder the rest of the fittings and pipe. This avoids getting the valve body too hot. This adapter is not really a "special" adapter, accepts a 1/2" pipe into one end and has 1/2" thread on the other. Very common, just ask for a 1/2" male adapter.
  1. Mystery shower valve? Danze, Global Union, Pegasus
    By DBIprop in forum Shower & bathtub Forum & Blog
    Last Post: 06-09-2013, 04:37 PM
  2. shower only rough in valve
    By joeriley2005 in forum Shower & bathtub Forum & Blog
    Last Post: 12-28-2011, 09:33 AM
  3. rough in tub/shower valve
    By GolfnRL in forum Shower & bathtub Forum & Blog
    Last Post: 01-13-2009, 07:10 AM
  4. Tub/Shower Rough In Valve
    By A Girl Can Do It in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-02-2007, 05:39 PM
  5. Shower valve rough-in, PEX...
    By mikepdaviskc in forum Shower & bathtub Forum & Blog
    Last Post: 02-14-2007, 09:48 AM
