Thread: Increasing pressure for pump, replacement?
    Questions from readers Guest's Avatar
    posts, emails and comments from readers reposted by Terry
    Default Increasing pressure for pump, replacement?
    We are trying to purchase a house in VT and the inspector we hired reports low water pressure throughout the house. We've never owned or rented a house with a well and I was curious as to how difficult and expensive replacing a below ground well pump is.
    I am an American Military Member's spouse. We live in the Middle East: Bahrain
    DIY Senior Member craigpump's Avatar
    Apr 2012
    ct
    Forget a home inspector, use an experienced, licensed well and pump contractor. Have a thorough well inspection performed along with a yield/recovery test done so you know exactly how much water the well makes.
    That said, it could be that there is a plugged filter, trash in the faucet aerators, the pressure switch might be failing, the pump might be worn, there could be a leaky pipe in the well.....
    Moderator valveman's Avatar
    Mar 2006
    Like Craig says, you could have one or more problem that needs to be ironed out. But just because you have your own well doesn’t mean you have to live with low pressure. On the contrary, you can have as much pressure as you want. Just don’t settle for anything less than want you want. It may require something as extensive as a new pump. But it could also be something as simple as adjusting the pressure switch a little.
  1. increasing water pressure
    By Mr Russ in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-04-2012, 12:52 PM
  2. Increasing well water pressure
    By thebone in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-09-2012, 07:53 AM
  3. Increasing pressure?
    By steve2278 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-10-2009, 04:56 PM
  4. Increasing Water Pressure
    By Cass in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-19-2009, 09:02 AM
  5. Increasing System Pressure
    By Budster in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-14-2007, 10:41 PM
