Thread: removing brown stains on grout without acidic product (don't want to etch it)
    DIY Senior Member AcidWater's Avatar
    Oct 2008
    Default removing brown stains on grout without acidic product (don't want to etch it)
    Just noticed that the 1966 shower tiles have a lot of brown stains in the grout. Got a product for stain removal but it says it might etch older tile, so I'd like to avoid using it.
    Bigger project is fixing the areas where the grout has come off, in 1/4" to 3/4" long strips. The grout line is really thin; less than 1/8" so the standard scraper I can buy is too wide. But wider than a grinding wheel on a Dremel. Maybe I can find some sort of a burr with the proper diameter to fit the width. Can I then use sealer over both old & new grout?
    Try cutting a hacksaw blade into 3-inch segments. You can grip them with a visegrip type tool. I have also used a utility knife, but that old grout is probably too hard for that.
    John Bridge, Ceramic Tile Setter :-)
    http://johnbridge.com/vbulletin/index.php
    Feb 2011
    NW Ontario, Canada
    Assuming the brown staining is rust, Super Iron Out does a good job for me and has not damaged the tile.
    As for removing grout, the Fein tool gets good reviews.
    Oct 2008
    I'll try the Super Iron Out...
    Actually I have the Dremel version of the Fine tool... haven't used it on anything yet. Wonder if there is a way to attach a fence to control the depth.
  1. Replies: 7
    Last Post: 03-25-2013, 09:01 PM
  2. Removing stains
    By HIGHLAND in forum Toilet Forum discussions
    Last Post: 12-30-2007, 04:05 AM
  3. Sink Stains
    By rdtompki in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-12-2007, 05:58 AM
  4. Removing old grout tile surface
    By Mike50 in forum Remodel Forum & Blog
    Last Post: 03-19-2006, 07:12 AM
  5. Removing stubborn stains from Toto sanagloss
    By mevans42 in forum Toilet Forum discussions
    Last Post: 08-29-2005, 02:34 PM
