Results 1 to 10 of 10
Thread: Kitchen p-trap/sink/pipe/drain predicament
    DIY Junior Member in need of help's Avatar
    Nov 2013
    Alberta
    Default Kitchen p-trap/sink/pipe/drain predicament
    This was done by a certified plumber. A home inspector advised me that i have no p-trap. Went back to the plumber and he reassured me that he created one and due to the distance this was the best he could do. I accepted it not knowing better. Recently sewee gasses have been backing up into the home so called the city inspector and they advised me i need a p-trap amongst other things. I have done my research but am not 100% sure on what to purchase or hot to properly assemble the pipes to have a proper p-trap installed. I feel the sink drain is too low for the wall drain. Not sure how to get a p-trap in there. I have attached a picture. Any suggestions? Name:  20131022_171732.jpg
    TROJAN WORLDWIDE SALES RP MACPLUMB 777's Avatar
    Aug 2007
    Houston, Texas, United States
    You have a trap just not a p trap! Not was not installed by a plumber just a handihack! You have to start back at the wall where that copper pipe comes from
    and lower the drain in the wall and the bring it back under the cabinet with a real
    p trap!
    MACPLUMB 777
    E-MAIL
    JERRYMAC@TROJANWORLDWIDE.COM
    35 YEAR MASTER PLUMBER, HEATING, ELECTRIC, DRAINS, FIRE SPRINKLERS, WATER HEATER
    AND BOILERS SINCE JAN, 1989
    281-706-1631 7 DYS A WEEK SALES AND TECH. SUPPORT
    Trojan Worldwide Web Site
    DIY Senior Member dj2's Avatar
    Aug 2013
    California
    Your plumber is certified? by whom?
    Anyway, the wall drain is too high - lower it and install a P trap.
    Master Plumber Caduceus's Avatar
    Oct 2013
    Pittsburgh, PA
    The basket strainers are a bit deep and by having a more shallow type strainer installed could get you more elevation for the p-traps and drainage piping. But it is definitely true that that is not a p-trap. Some certified plumbers will do shoddy work to save time and money.
    The way I would do it is to cut open the wall and lower the drain. A p-trap could then be installed on each of the sink bowls. If the venting of the traps is an issue, each trap could be equipped with it's own approved auto vent. It also looks like there is a dishwasher discharge connection on the drain that is not connected or plugged off. If the wall cannot be cut open, then by using the shallow basket strainers that I mentioned and the auto vents for each trap, you could still have the proper installation.
    Of course we don't really expect you to do the work since you already paid a plumber to do it, but maybe printing a copy of this thread and showing the plumber it will remind him of how things should be done.
    Don't give up on this problem, plumbing inspectors are there to look out for your health and safety and keep tabs on poor plumbing practice.
    Short
    Long
    The "design" of a drain determines whether you have a "P" trap or not, and since yours IS a "P", you do have a P trap, but it is an assembled one, not a premade design. Your drain is a candidate for a two trap installation, because there is no way to connect the two drains together and still be above the wall pipe.
    Nov 2013
    Alberta
    Thank you all for ur remarks and suggestions. They guy who did the nstall is licenaed and worka for Always Plumbing. I wont discredit the company because of one plumbers make shift p-trap. I will see about lowerirthe drain and putting in a manufactured p-trap. Thanks again!
    Did you see what I said about TWO "P" TRAPS, so you would not have to go to the expense of lowering the drain line, if it were even possible in your situation.
    DIY Member hboogz's Avatar
    Mar 2013
    New York
    hj -- trying to shore up my knowledge. In the event that a drain is that high, it's always best to install a P-trap for each sink and, if possible, use shorter strainer's ?
    What he is saying here, You're boxed in a corner and this may be your only option.
    If the drain in the wall is vertical, you can cut in the tee lower.
    If it's horizontal, you may have to pull cabinets out until you find that vertical piece.
    Or..........you can arm over from where it is now, wye off for the second trap and get it done as best you can.
    Right now, most of the mess that is under there is under water, all the time.
    Mar 2013
    New York
    Thanks for the info.
  1. Sweating Cu Pipe and Kitchen Sink P-Trap Questions
    By KP Texan in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-29-2009, 07:58 AM
  2. Kitchen sink drain and trap
    By shawnkey in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-16-2007, 09:35 AM
  3. Leak at P-trap/drain connection with new kitchen sink
    By jmaland in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-16-2007, 08:12 AM
  4. Loosen kitchen sink drain pipe
    By Mikemonica in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-25-2006, 04:34 AM
  5. bathroom sink drain pipe and p-trap don't meet
    By rexballinger in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-14-2005, 02:17 PM
