chroipahtz
Hello all. I am not much of a DIYer, but I am learning due to this problem that's left me without hot water for several days now.
My previous gas water heater sprung a leak and started leaking into the carpet, so I had it replaced. It was still providing hot water, just it was leaking and beyond repair. I have a nice shiny new unit in there now, but I am not getting any hot water to the 3 sinks and 2 bathtubs in my house; instead, cold water is coming through. I haven't tested the dishwasher and washing machine, but I see no reason to, as I'm sure they'll also be getting cold water instead of hot.
Here are some facts: (bolded the 2 most interesting/important facts in my view)
Going out of my mind here... I asked two of my friends who are plumbers and they don't see anything wrong with the installation and are just as stumped as I am. Remember: The old heater supplied hot water, but the new one doesn't, and it is clearly heating the water because I drained hot water from it. Any ideas? Thanks so much.
- After installing the new heater, there was air in the pipes, but leaving the faucets on for a few minutes returned the flow to full.
- No leaks in the water heater or pipes coming into it or out of it that I can see. I don't think this is necessarily a hidden plumbing issue because the old heater worked.
- Pilot light and burners are working fine. Setting the temperature higher causes the burners to come on as expected until the water is the right temperature.
- All valves are open fully, gas valve is inline with the pipe, etc.
- I drained some water from the tank using the drain on the tank and it is very hot, so I strongly believe the heater is doing its job.
- The hot water outlet pipe is fairly hot (but not too hot to touch) near the tank, but it quickly gets colder and colder just a foot or so away from the tank, as it goes into the wall. Does this suggest a buildup of sediment in this pipe, so no hot water is getting out? This doesn't make sense to me either because the old heater worked.
