plummerputty
Took my lavatory drain apart to unclog a hairball, and when I put all the pieces back together, I had leaks..., then I started reading up on connecting AC condensate lines, codes, etc.
The whole plumbing layout did not look right to me, with vertical extensions on the p trap. Each of those additional joints were a leak waiting to happen. I decided to try to fix it right, which is why I'm posting here.
My idea is to do away with the existing rigid AC condensate line and replace it with flexible tubing; I would cut the PVC a few inches from the sheetrock, attach the flexible tubing at the stub, and run it from there to the tailpiece, maintaining a slight grade.
The problem comes in attaching it to the tailpiece. I've found a 1-1/4" fine-thread Lavatory Branch Tailpiece (available at wholesalers?) that solves the problem of attaching the condensate line to the tailpiece, but creates the problem of how to attach the pop-up stopper rod.
Am I missing anything here?
Any help is appreciated. Thanks in advance.
