Page 2 of 2 FirstFirst 12
Results 16 to 28 of 28
Thread: Draining a Water Softener
  1. #16
    Feb 2011
    NW Ontario, Canada
    Wow! I'da never thunk so many would interpret it as either/or.
    also
    ˈɔːlsəʊ/Submit
    adverb
    1.
    in addition; too.
    "a brilliant linguist, he was also interested in botany"
    synonyms: too, as well, besides, in addition, additionally, furthermore, further, moreover, into the bargain, on top (of that), over and above that, what's more, to boot, else, then, equally; More
    I guess the OP could have taken it the wrong way also.
  2. #17
    Feb 2011
    NW Ontario, Canada
    Be careful using a vacuum on a tank. See picture for explanation of why.
    Attachment 22184
    Ja, I have warned people in the past that what you show can happen when they want to add a booster pump after a pressure tank, softener, or iron filter.
    http://www.terrylove.com/forums/show...l=1#post339249
  3. #18
    Central Florida
    Wow! indeed. How thick are the sidewalls in those tanks?
  4. #19
    also
    ˈɔːlsəʊ/Submit
    adverb
    1.
    in addition; too.
    You had this "Assuming it is not one of the reverse flowing type, that should push the water down through the bottom basket and up the tube." between the air part sentence and the vac sentence.
  5. #20
    Feb 2011
    NW Ontario, Canada
    Classic mistake in writing 101... know your audience.
    I do technical writing in my field and need to be reminded of that from time to time.
  6. #21
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    The audience here will remind you everytime. LOL
  7. #22
    DIY Junior Member KimbaWLion's Avatar
    Oct 2013
    JUST outside Philadelphia
    This pictures just look PAINFUL!!! My tank is suppose to be stainless steel but I wonder if it is that way all they way through...
    But as you can see Fiberglass does not do well in compression...
    I may NOT be the best guy BUT I am NOT the bad guy! -Coop from Megas XLR
  8. #23
    DIY Junior Member batman71's Avatar
    Aug 2012
    Well, I just got done draining the resin tank using one of the above prescribed methods. I have an old (30+ years) Shop Vac with the capability of moving the hose to the outlet side. Try to find one on the market today that has that....not sure why they did away with that feature. But, I digress! I used this vacuum to apply pressure to the inlet on the softener head and used another vacuum to suck the water from the outlet. Worked like a charm. Thanks!
    Batman71
  9. #24
    Nov 2010
    Maine
    Quote Originally Posted by batman71 View Post
    Batman71
    I think ridgid still makes one.
  10. #25
    Central Florida
    I don't know of any household vacuums that blow as well as suck, either. Looks like a conspiracy.
  11. #26
    Feb 2011
    NW Ontario, Canada
    I've seen shop-vacs with a removable powerhead so you can use it as a leaf blower. I'm guessing it would suck and blow at the same time.
  12. #27
    IMO the teacher is only as good as the student.... In this case I'm glad to see that Batman got'er done and the tank should be lighter. Although I do wonder how he knew when to stop so as to not blow/suck resin up in the valve and out of the tank. Also IMO, he will see if this created any problems after he installs the softener in his new place.
  13. #28
    Feb 2011
    NW Ontario, Canada
    Since the blowing and sucking was purportedly all in the forward direction, no resin would have been harmed during filming the movie.
  1. Draining a water softener into a septic system...bad idea?
    By Mikebarone in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-24-2013, 06:20 PM
  2. water constantly draining need help not sure if its pressure tank or softener problem
    By marisa rae in forum Water Softener Forum, problems, installation and reviews
    Last Post: 05-02-2013, 04:25 AM
  3. How to empty water softener? (Kenmore deluxe demand water softener 625)
    By birkoff in forum Water Softener Forum, problems, installation and reviews
    Last Post: 01-22-2013, 08:56 PM
  4. Draining Water Softener - Seasonal Cottage
    By chuck b in forum Water Softener Forum, problems, installation and reviews
    Last Post: 07-19-2011, 04:11 PM
  5. Water softener draining
    By Pedelty in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-26-2008, 10:30 AM
