Page 1 of 3 123 LastLast
Results 1 to 15 of 31
Thread: Raimondi Tile Leveling System
    DIY Junior Member Natup's Avatar
    Oct 2013
    Toronto
    Default Raimondi Tile Leveling System
    Hi all - first time poster; long time reader. I'm gearing up for a complete DIY bathroom reno. I was thinking about purchasing the Raimondi Tile Leveling System as I have large format tiles. To anyone who has used this system: Can I get away with just purchasing the wall plier for both walls and floor (the floor space is relatively small).
    Hal
    Toronto, ON
    As opposed to what one poster says (he has issues), there's a lot of good info at www.johnbridge.com/forums There's a discussion on this (and others) there that may help you decide. http://www.johnbridge.com/vbulletin/...eveling+System
    Jul 2009
    North Vancouver, BC
    Default Raimondi Tile Levelling System - Review
    Post(s) deleted by John Whipple
    A leveling system won't correct an improperly prepped floor, but will help keep the tile in nice alignment. Regardless, it is critical on any tile install to have full coverage on all edges and at least 80% (100% should be your goal) of the interior of the tile. Tiling 101, periodically, after setting, pull up a tile (or membrane, or whatever) and check your coverage. You may need to adjust your thinset, trowel, or technique.
    Jul 2009
    North Vancouver, BC
    Jul 2009
    North Vancouver, BC
    Default How to Install and Removed "Raimondi Tile Levelling System"
    FWIW, the instructions on most (if not all) of the leveling systems tell you to not put the clips right at the corner, otherwise, you could snap it off. If you install the clips and thinset the job properly, the edges are fully supported. Your goal should be to get the entire tile fully supported, but they allow some leeway on the interior. Depending on the tile, the substrate, and the thinset used, you may want to wait longer than overnight to knock the tabs off. This is especially true if you're using a membrane and a modified thinset, which could take a very long time for the modifiers to dry. The larger the tile, the longer the wait (when using a modified).
    DIY Junior Member cheakamus's Avatar
    Feb 2011
    Seattle, WA
    Quote Originally Posted by johnfrwhipple View Post
    Just Saying.
    From the Urban Dictionary:
    1. just sayin'
    word of the day: January 18, 2011
    a term coined to be used at the end of something insulting or offensive to take the heat off you when you say it.
    Quote Originally Posted by cheakamus View Post
    1. just sayin'
    And, you'll note I said the same thing...100% of the edges, and 80% minimum of the interior (with 100% being the goal).
    It's just John throwing darts again.
    Oct 2013
    Toronto
    Jim - thanks kindly for the link - unfortunately I didn't find reference to the tool specification (wall or floor) issue. I am gutting the bathroom down to joists and studs to create a perfectly flat floor (and walls).
    John (btw - I love your work on HouseBuzz)- large format tiles? - perhaps not the best idea for the diyer - but I am determined (and perhaps overly confident; and certainly too poor to afford a high-end (and frankly hard to find) tiler here in Toronto). Regardless, I can live with my own imperfections - Just saying
    My understanding was that the system might help reduce lipage - especially on the long format parcelanosa wall tile (below).
    btw - I was under the impression that some of the images that you have posted elsewhere contained leveling clips?? I suppose you believe that with the RLS the tiles might crack and dislodge?
    Hal
    One installer that has done this a lot claims he uses the TLS and can remove the (slight) bow on long tiles like that. It will always make the adjacent tile edges level with each other, but if the tile isn't flat, that may not mean no lippage. I'm a little skeptical, but he says he does it all of the time. This system (http://www.flooringsupplyshop.com/ra...-100-1551.html is similar to the LASH system, but comes with a tool...on LASH, you just use your fingers to slide the wedge tight. The TLS's tool is more like an adjustable zip tie gun. You can use it to break the tab after the thinset cures as well by adjusting it tighter to snap it off.
    Jul 2009
    North Vancouver, BC
    Oct 2013
    Toronto
    OK, thanks guys. Lots to consider. I now have the floor removed - sistering joists to create level. Unfortunately, its the only bath/shower in the house - seems like a long way off to tiling (and showering). John, I may pick you brain a bit to consider lighting. Will head to your site when I get a chance..
    Jul 2009
    North Vancouver, BC
    Jul 2009
    North Vancouver, BC
    Default Tile Layout Plan - Planning layouts with Raimondi Tile Levelling System
  1. Leveling a self leveling Jacuzzi
    By Spud Farmer in forum Shower & bathtub Forum & Blog
    Last Post: 02-02-2013, 11:56 AM
  2. leveling a tub
    By Taylor in forum Shower & bathtub Forum & Blog
    Last Post: 09-04-2010, 02:19 PM
  3. heated flooring system -w/ tile
    By busy2muchgiongon in forum Remodel Forum & Blog
    Last Post: 11-06-2009, 11:50 AM
  4. Tile floor leveling
    By Bentley in forum Shower & bathtub Forum & Blog
    Last Post: 06-06-2009, 02:51 PM
  5. Toilet Slab/Tile leveling project
    By heidi101af in forum Toilet Forum discussions
    Last Post: 05-20-2008, 04:23 AM
