Results 1 to 12 of 12
Thread: Gould J10S w/ Cracked Cast Iron Parts and Other Problems
    DIY Member BillyJoeJimBob's Avatar
    Jul 2011
    San Antonio, Texas
    Default Gould J10S w/ Cracked Cast Iron Parts and Other Problems
    The motor works just fine.
    1) The Casing (1K333) is cracked where the pump was not drained properly and water froze inside, and then some time before I acquired it, the crack was welded badly. I've ground-down the bad weld to fully-expose the crack, in preparation for getting it welded again.
    2) I broke one of the dog-ears off the Motor Adapter (K310) by over-tightening it. I think it can be welded & repaired.
    3) I broke the Impeller (2K61) by tapping it with a rubber mallet, trying to loosen it from the shaft.
    3) Finally the Diaphragm (5K162) is stiff, rusty, ragged and looks like it needs to be replaced.
    I've made a few phone calls and have been told that you cannot by just the pump assembly; you can only buy the (expensive) parts one at a time. I've looked online and it appears the pump is the "weakest link" as I find no one selling a broken J10S with a bad motor & good pump.
    I'd like to rebuild the pump and put it into service as a booster pump, with a adequately performing Grundfos MQ, or failing that, either do "something" with the motor, or sell it. But I cannot find a market for these motors, even though they seem to be high-quality. Can I buy a non-Gould pump and use this motor with it? I have this working, seemingly high-quality motor and am looking for a way to avoid throwing it away. Any help?
Size:  56.8 KBName:  pump2.jpg
Size:  68.3 KBName:  pump3.jpg
Size:  64.2 KBName:  pump4.jpg
    Sprinkler Guy Wet_Boots's Avatar
    Mar 2007
    Metro NYC
    Welding cast iron is generally a pathway to failure. Why not keep the motor as a spare for a new J series pump?
    Jul 2011
    San Antonio, Texas
    Quote Originally Posted by Wet_Boots View Post
    Is it cast iron? I just assumed it was because it was bumpy. The previous weld might have worked if it hadn't been 1/8" off the crack, lol...
    If I were to buy another pump, I would want something heavier-duty? Besides that, I don't see the motor likely to go bad. I've had this thing laying around for a couple of years and it's time to do something with it.
    Mar 2007
    Metro NYC
    Any cast iron pump that has water freezing in it will die an early death, and heavy duty don't enter into it. The Goulds J+ series jet pumps are top quality items.
    All that said, the motor is a standard pump motor with a 56J frame, so maybe you can find a burned-out pump to match it up with.
    Well Drilling/Service justwater's Avatar
    May 2010
    NE FL, SE GA
    like wetboots said, J10 is top of the line but nothing cast iron and full of water is gonna stand up to a freeze. did you call around to any drillers/installers to see what they had laying around? i know ive got a couple used pump ends for that motor, good chance some others closer to you do too... for cash no doubt. good luck
    Moderator valveman's Avatar
    Mar 2006
    I have always had better luck with brazing on cast iron.
    Mar 2007
    Metro NYC
    ...and the nice thing about a good used pump end from a dealer, is that the impeller has already been safely removed, so no rubber mallet required...
    DIY Senior Member craigpump's Avatar
    Apr 2012
    ct
    A competent welder using nickel rod can fix that, but it may distort from the heat.
    Mar 2007
    Metro NYC
    I'd still think the money would be better utilized on a used pump end, or a local bargain on a lightning victim pump.
    Apr 2012
    ct
    No argument there, I wouldn't waste my time on it either.
    Mar 2011
    Houston, TX
    Cast Iron can be repaired, If done properly.
    The key is to heat the complete piece up, before attempting to repair the bad area.
    Some Backward Welders use a gas Grill to preheat the work piece.
    Next time you should consider using a Torque wrench, and make sure everything is lined up properly.
    May be best to buy another, I would not trust that one unless I used JB Waterweld. LOL
    Good Luck.
    Jul 2011
    San Antonio, Texas
    Good Luck.
    The JB Weld. Was that a joke? Because I'm thinking about trying it.
  1. Cracked Cast Iron Stack or junction between toilet and shower
    By cathychis in forum Shower & bathtub Forum & Blog
    Last Post: 09-20-2011, 10:10 AM
  2. Cracked cast iron 4-way Tee in Vent stack/sewer drain in bathroom
    By Rudy6897 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-18-2011, 08:40 AM
  3. Cast iron motor adpater cracked Goulds Motor Apapter Part#1K310
    By on02151blueline in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-18-2010, 04:56 PM
  4. repair a gould j10s
    By rny1tl in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-21-2009, 04:27 PM
  5. Help - Gould J10s
    By dreyes731 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-22-2006, 11:54 AM
