Thread: Electrical Panel in closet. A no no but what if...
    DIY Junior Member gakenyon's Avatar
    Oct 2013
    Seattle
    Default Electrical Panel in closet. A no no but what if...
    So I am planning a garage conversion and putting a bedroom in the garage. My current plans call for a 5' deep closet running the length of the room (~ 14') but then I realized that the electrical panel would now be in a bedroom closet. I have read the NEC and know that it says not in the vicinity of combustibles and not in spaces such as a clothes closet.
    But what if...I built two partial walls on either side of the electrical panel , 30" apart and out 2' - 3'? Would this be enough seperation from clothes hanging on the other side? would I have to enclose the front as well and add a door?
    I understand the need to not locate it near combustibles but right now it is in my garage and a shelf is located below in and another to the right (previous homeowner). but typically garages become storage spaces anyway so the requirement is kind of hokey and vague. It should list dimensions for clearance from combustibles. My two cents.
    thanks,
    gak
    Jun 2007
    North Carolina
    make three closets, two for cloths and one for the panel equipment room. Yes there will need to be separation from the closet by being surrounded by walls and a door.
    When I built my last home, but it was many years ago, the only limitation on the panel in the closet was that it had to have 3' of clear space in front of it.
  1. Electrical inspection - panel upgrade
    By jjwire in forum Electrical Forum discussion & Blog
    Last Post: 02-06-2012, 06:21 AM
  2. Opening Up and Electrical Panel
    By moeronn in forum Electrical Forum discussion & Blog
    Last Post: 11-03-2009, 05:31 PM
  3. Rewiring a 200 Amp electrical panel
    By Ian Gills in forum Electrical Forum discussion & Blog
    Last Post: 10-14-2009, 06:12 PM
  4. Hot water tank clearance from electrical panel
    By rmelo99 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-30-2008, 06:39 PM
  5. Which brand of electrical panel?
    By FrankPlumber in forum Electrical Forum discussion & Blog
    Last Post: 03-05-2008, 07:36 PM
