Thread: pressure surge
    DIY Junior Member louie 44's Avatar
    Oct 2013
    Richfield Pa
    Default pressure surge
    Hey everyone, have a 30 50 pressure switch, when the pump kicks on it produces pressure on cold side,
    just blows out like a air gun, it actually blew out toilet valve in tank.
    I have drained the pressure tank and its at 28 which is where it should be, anybody out there have any idea
    what may be and how to fix
    Feb 2011
    NW Ontario, Canada
    Is it blowing out air? If so, I suspect you have a checkvalve at the tank and water falling back to the well creating a vacuum sucking air in. Was there a galvanized tank before with an airmaker/snifter?
    Aug 2009
    South*East
    Quote Originally Posted by louie 44 View Post
    I have never seen a pressure tank with a hot side.
    John
    Moderator valveman's Avatar
    Mar 2006
    This seems to be a day in which many people are learning about the problems a second check valve in a pump system can cause.
    You probably have a bad check valve on the pump or a hole in the drop pipe. But it would not be getting air if you didn’t have an extra check valve, most likely above ground.
    Remove the above ground check valve. It is masking the real problem. Then if the pressure drops with the pump off and no one using water, the check on the pump or the hole in the drop pipe will need to be fixed.
  1. Thermal expansion tank / pressure surge
    By purduephotog in forum Water Heater Forum, Tanks
    Last Post: 12-24-2012, 08:25 AM
  2. pump surge
    By Doubler in forum Pumps and Tanks Well Forum & Blog
    Last Post: 11-19-2009, 12:13 PM
  3. TR Surge Receptacle
    By dhla in forum Electrical Forum discussion & Blog
    Last Post: 04-02-2009, 03:21 PM
  4. Whole house surge . . .
    By sjh in forum Electrical Forum discussion & Blog
    Last Post: 12-30-2007, 10:49 AM
  5. Pump chatter/surge at pressure switch
    By jmdeng13 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 11-29-2006, 11:36 PM
