Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Thread: Black poly tubing for potable water
    DIY Junior Member leak_chaser's Avatar
    Aug 2013
    South Carolina
    Default Black poly tubing for potable water
    How can I tell which black poly tubing is for potable water and which isn't? Which rating/certification do I look for? The Home Depot website does not state in plain English if the tubing is for potable water or not.
    Thanks.
    Aug 2013
    South Carolina
    This is for an underground line from the meter to the house.
    Not sure what you mean by formulation.
    Here is a few links:
    This one has no certifications or listings:
    http://www.homedepot.com/p/Advanced-...0300/203013666
    This one is DWV rated and NSF listed (whatever that means):
    http://www.homedepot.com/p/Advanced-...specifications
    This one is NSF listed:
    http://www.homedepot.com/p/Advanced-...0100/202967364
    I tried the manufacturer's website but no luck.
    NSF listed. 200 PSI
    If it's a 2-3 bath, 1" will do depending on distance.
    Mar 2011
    Houston, TX
    Quote Originally Posted by leak_chaser View Post
    I would not use that kind of tubing for your application , if it is approved or not.
    Plenty of sand may let it work for awhile.
    I would not cut corners on your install.
    Daddy Terry knows best.
    Aug 2013
    South Carolina
    Thanks. But what would you use?
    Mar 2011
    Houston, TX
    Something rated over 160 PSI.
    Schedule 40 PVC would be my choice.
    That 1 inch that you listed is not all that great.
    Nov 2010
    Maine
    If you are running underground from the well or city water main you want 160lb rated poly. Around here, thats pretty much all we use, including the city water departments.
    Mar 2011
    Houston, TX
    That is some pretty thin stuff.
    I guess the city water department would like to use it. You Pay for the leaks and keep them in work digging it up and replacing it.
    Nov 2010
    Maine
    Its actually pretty thick stuff and if properly bedded it will never leak. Its the same stuff we hang submersible water pumps on.
    quote; including the city water departments.
    Our local paper just had a picture of some water department employees removing the poly supply to the meters and changing to copper tubing. So it seems it is NOT the panacea that everyone thought it would be, but then that has happened with a lot of plastic piping over the years.
    Sprinkler Guy Wet_Boots's Avatar
    Mar 2007
    Metro NYC
    Yesteryear's 160-psi poly has become today's 200-psi poly, by way of newer high-density resins. The old 160-psi poly made from medium-density resin is still available, but is mostly used in wells, for submersible pumps.
    The key for potable water usage is the NSF-Rated labeling, insuring that all virgin resin went into the manufacture of the poly.
    Buried as shallow as it figures to be in South Carolina, I'd consider sch 40 PVC instead, unless they got some good reason not to use it.
    DIY Senior Member craigpump's Avatar
    Apr 2012
    ct
    Use 160 or 200 psi poly from a reputable manufacturer like Charter Plastics, bed it in sand and be done with it.
    Nov 2010
    Maine
    Agreed. I NEVER use PVC for water supply, either below or above ground.
    Quote: I NEVER use PVC for water supply,
    Around here PVC is about the only thing that is used.
    DIY Senior Member Reach4's Avatar
    Sep 2013
    I don't have experience with any of this. I found this article of interest: http://www.usplastic.com/knowledgeba...contentkey=782 --in particular, the discussion of thermal expansion and contraction. They seemed to only be worried about it for when the cement was not totally hardened, but I wonder if some consideration would make sense for long runs over the long term.
  1. ABS to Black Poly Pipe Connection
    By Gary the Electrician in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-16-2012, 08:43 AM
  2. Tip on Wrangling Black Poly Coil
    By rmelo99 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-06-2009, 07:51 PM
  3. Poly Tubing for Drinking Water
    By samdog in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-27-2009, 02:22 PM
  4. Copper to Poly (black PE) transition
    By Count Fred in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-12-2008, 06:00 PM
  5. black poly pipe
    By dennis p in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-07-2006, 08:26 AM
