Results 1 to 6 of 6
Thread: Delta 1500, Determining What Model Shower Valve
    DIY Junior Member dcsmith37's Avatar
    Oct 2013
    Omaha
    Default Delta 1500, Determining What Model Shower Valve
    I have a slow drip leak with my Delta shower valve. I am trying to determine what model Delta valve it is and have attached a few pictures. Any advice would be greatly appreciated. Thank you.
    Oct 2013
    Omaha
    The leak is in the shower head.
    The leak is in the valve, the water comes OUT of the shower head. It is probably a model 1500, but if so you have to know the year it was made because the new ones do not fit the old body. The easiest way to tell is to remove it and compare it to the ones at a parts store. Once will have blue "legs" and the other will be white.
    Oct 2013
    Omaha
    Well, I'm in a bit of a mess. Everything came out as it should except the white housing part inside the brass part of the housing. I've tried to get it out but it's coming out in pieces... I still need to get it out, any suggestions?
    I assume your rotated off the collar that holds the cartridge in first. Counter clockwise.
    After that, you just have to show it who's the boss.
    A bit of wiggle helps.
    Pull harder.
  1. Delta 1500 Series Monitor shower head etc
    By stuckwitholddelta in forum Shower & bathtub Forum & Blog
    Last Post: 05-28-2013, 10:00 AM
  2. Delta 1500 to 1700 sleeve too short
    By cgamundson in forum Shower & bathtub Forum & Blog
    Last Post: 04-08-2013, 07:06 AM
  3. Calling Delta Experts: Do I have a 1500 or 1700 Series Shower Faucet/Trim Kit?
    By BG in Detroit in forum Shower & bathtub Forum & Blog
    Last Post: 01-18-2013, 06:34 AM
  4. determining valve model
    By wallywombat in forum Shower & bathtub Forum & Blog
    Last Post: 01-04-2013, 12:19 PM
  5. Shower trim kit for Delta 1500/1700
    By JohnBob in forum Shower & bathtub Forum & Blog
    Last Post: 10-20-2012, 08:56 AM
