Results 1 to 5 of 5
Thread: Low flush toilets causing sewage pipe clogs???
    DIY Junior Member mrgooch's Avatar
    Oct 2013
    NJ
    Default Low flush toilets causing sewage pipe clogs???
    It is my belief that using toilets with a low volume of water to flush waste would or could eventually cause a blockage in the sewer pipe. Wouldn't waste and paper tend to collect without a volume of water to move it?
    At my mom's home, her sewer line is 250 feet 4" clay pipe.
    She has two 1.6 bowls and one 3.5
    The 3.5 has much slower drainline carry than the 1.6 bowls.
    That line has been there since 1962 and the only time we snaked it was when paper caught on a gas line that had been drilled through the clay pipe.
    We cut the pipe with the cutters on the snake and had the gas company out to relocate the gas line. It's been fine ever since.
    Warning: Cutting a gas line inside a sewer line can have serious problems.
    Sep 2013
    That could be spectacular. That's got to make its way into the storyline for a movie.
    Oct 2013
    NJ
    Hello Terry
    Have you ever heard of this concern before?
    I hear about the worry, but then I've installed thousands of 1.6 and 1.28 gallon toilets without issues.
    I've also heard about old homes with old lines and old toilets that need snaking every other year because of roots and cracked lines. More water doesn't help with roots. It just makes more of a mess when it backs up.
    Here is a video of a 1.1 gallon flush
  1. I think clogged rim jets are causing a weak flush
    By 12ax7 in forum Toilet Forum discussions
    Last Post: 05-04-2011, 09:33 PM
  2. Galvanized drop pipe causing iron issues?
    By TJanak in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-24-2009, 08:18 AM
  3. Flush up toilets
    By macombvan in forum Toilet Forum discussions
    Last Post: 09-21-2008, 12:01 PM
  4. Diverter Causing BANG in pipe.
    By duworm in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-05-2006, 11:26 PM
  5. Dual flush toilets
    By jsplays in forum Toilet Forum discussions
    Last Post: 05-30-2005, 10:53 AM
