Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: bathroom layout right or wrong pics included
    DIY Junior Member itmyfault's Avatar
    Dec 2012
    Arkansas
    Default bathroom layout right or wrong pics included
    Hey everyone I am working on remodeling our bathroom. I have spent the last few days getting the first part of the drain lines relocated. I wanted to get some input on how I am doing so far. I have been reading the UPC 2006 code book which is the code for my city.
    I know I got a little carried away on the primer in places!
    What you see is the lav drain connecting into the WC branch. The WC branch connects into the main drain. The lav will be wet vent the WC. Proved I understood the code and did it correctly.
    Thanks for the input.
    Billy
    That looks good.
    The santee for the lav can be a 2" x 2" x 1.5" with the 1.5" pointing out for the lav.
    If this bathroom is at the end of the run and needs a cleanout, I sometimes bring up the vent under the lave with a 3", 3" cleanout tee, and have the 2" for the vent and lav waste above that.
    By end of the run, you can be within five feet of a line with a cleanout, and you don't have to add one.
    It looks like you understood what you were reading.
    Aug 2009
    South*East
    Looks good Billy. What would make it easer would be if you used a 4 x 3 ell for the toilet, with the 4" coming up through the floor. That way the closet flange would fit inside the pipe instead of over it.
    Terry you got me by one minute.
    John
    That's my favorite method too.
    Oct 2011
    Looks like Terrys horizontal wet vent diagram that he posted yesterday on another thread.
    Dec 2012
    Arkansas
    Thanks Terry I appreciate your thumbs up. I tend to research stuff to death according to my wife. I spend countless hours on the internet and reading books. I then spent an afternoon at the code enforcement office going over things with the inspector. I wanted to do it once and do it right.
    The main line runs at perpendicular to the WC line shown. The WC line connects to the main by a 3 wye combo. This was the orginal WC line originally and I just extended 3 ft to the other side of the room along with the lav.
    The main runs straight through the house from the back wall to the street. There is a cleanout located on the back of the house at the end of the main. I was stuck on whether to add a cleanout or not. The inspector told me I didn't have to have one. Do you think I should add one here?
    I went back and forth on using a all 2" tee or the 2x1.5 tee. I actually bought both. The original plumber used a all 2" tee and a reducer. I just decided to copy what was there.
    My wife says it is because I am "anal retentive" whatever that may mean.
    Oh yeah I did use the 3 x 4 WC elbow. I discovered that little jewel when I dug at the old WC location! I like the inside mount too.
    Then I would go with that.
    We have a lot of that here
    Dec 2012
    Arkansas
    Thank you all for taking the time to give input on my "while we're at project."
    This is part 1 of the rough in. I now have a bathtub and separate shower to run pipe for. I will post the pics of that work when I get it put together.
    Billy
    quote; if you used a 4 x 3 ell for the toilet, with the 4" coming up through the floor. That way the closet flange would fit inside the pipe instead of over it.
    I have ALWAYS used a 4x3 closet bend, but I also ALWAYS slide the flange down OVER the outside of the pipe. Anal retentive means you are full of poop..
    Dec 2012
    Arkansas
    Here is the proposed shower drain layout
    Dec 2012
    Arkansas
    I wanted to get some thoughts on my next connection layout before I glue it all together. I want this to work well AND be up to code. After digging everything up what I found was slightly different to what the builder told me.
    The code official told me to remember 2 main things.
    1. Don't over complicate things.
    2. Keep it simple and straight forward as possible.
    So this is my first attempt at adapting to what is there.
    Attachment 22124Attachment 22125
    Looking good
    You can roll the wye so that the pipe lines up nice and square in the hubs.
    You may need to snap a bit of concrete off the corner there.
    Dec 2012
    Arkansas
    I am trying to get a layout for my shower line.
    Dec 2012
    Arkansas
    Any advantages to inside or out? I guess should the flange every break it would be easier to replace???
    Aren't we all??!! Some just more than others!
    Dec 2012
    Arkansas
    ok here is my final revised plain for the shower drain. How does this look?
  1. Well Retention Tank questions (PICS included)
    By mrmichaeljmoore in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-03-2009, 04:07 PM
  2. rough in help. pics included
    By buzzard in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-27-2008, 07:17 PM
  3. help with basement rough in. pics included
    Last Post: 04-21-2008, 04:23 PM
  4. Need help with plumbing utility sink - Pics included
    By cowdog in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-04-2008, 06:01 AM
  5. Washer/sink rough in question - pics included
    By lisa99 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-12-2007, 10:47 AM
