Results 1 to 5 of 5
Thread: Home Made Down Draft Rig for finishing woodwork
    Jul 2009
    North Vancouver, BC
    Default Home Made Down Draft Rig for finishing woodwork
    Hey everyone.
    Anyone here build a down draft rig for finishing woodwork. I'm repairing a couple of doors and am not please with the finish. Thinking I could rig up a down draft rig to improve on the end result.
    Can figure out I think the box and holes but was wondering about what kind of fan and how to filter the air. Was thinking I could use my Delta Air Cleaner and maybe some furnace filters. Worried that the Air cleaner puts out to much air speed.
    Any ideas would be great.
    Thanks.
    DIY Senior Member DougB's Avatar
    Jun 2010
    Minneapolis - Land of 10,000 taxes
    I do a lot of wood working - as a hobby. What kind of finish - solvent or acrylic? What's the tempature? For doors they need to be flat - on saw horses. What kind of problems have you encountered?
    If a hammer won't fix it, it's an electrical problem.
    Jul 2009
    North Vancouver, BC
    Default Home made Down Draft Work Table
    Doug I typically use Laquer on my wood working jobs. I blow out my shop run a few hepa filters and spray away. Any fine particles get sanded out with a lemon oil sand at the end.
    These doors however are front doors and exterior. Dark Stain South Eposure - worst combo.
    I'm working with Varathane Exterior water based Semi-gloss finish. Only finish I can find locally approved for outside. The finish is slower drying and I'm getting dust settling in my clear coats.
    Went today to buy a down draft rig - but no one sells them.
    Hit the Home Depot for a few furnace filters and am going to make my own with some plastic, some ram board and some painters tape. Hoping the down draft keeps any dust from entering the work table. Doors are both flat on my shop table.
    I'm worried about dust entering the system via my air cleaner so I bought a new air filter bag for it.
    I'm going to rig in another furnace filter before I send air to the air dispenser I will make. I'm hoping this works. These clients of mine have been waiting forever for me to fix the doors and I want to deliver a nice (Pefect) end result.
    Will post some pictures tomorrow once I finish building my rig.
    My woodshop is 500 square feet. it is heated to 19 degrees Celsius why my clients doors are there.
    Jul 2009
    North Vancouver, BC
    So no luck with building a down draft rig.
    I did try making a side blowing contrapation that worked OK but still lots of tiny dust in my top coat.
    Going to lemon oil the door with some 800- grit wet dry sand paper.
    That should take some of the shine of the door and the dust bunnies at the same time.
    JW
    Mar 2011
    Houston, TX
    Are you using a squirrel cage blower ?
  1. Home-made water heater
    By molo in forum Solar and Geothermal Water Heating Forum
    Last Post: 07-30-2011, 10:36 AM
  2. Home made P-Trap
    By rmateyko in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-09-2008, 07:42 AM
  3. finishing basement???
    By wfhjr1976 in forum Remodel Forum & Blog
    Last Post: 01-09-2008, 06:22 AM
  4. Home-made water heater
    By molo in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-13-2007, 07:05 PM
  5. Shower Finishing
    By Lucien in forum Shower & bathtub Forum & Blog
    Last Post: 10-25-2006, 06:32 AM
