Page 8 of 11 FirstFirst 1234567891011 LastLast
Results 106 to 120 of 165
Thread: Toto Ultramax product review, comments & pictures
  1. #106
    As far as I know, none of the low-flow toilets use all the water in the tank...they all have more in there which helps give it a bit more oomph (sort of like a water tower). The only way to get a toilet to use all the water in the tank these days is to either hold the handle down, or substitute incorrect parts, and then, at least with a good toilet, you're wasting water. G-Max has been Toto's best flushing system. Their newest one is the dual-cyclone flush used on some of the newest low-flow HET toilets. Any of them that use the 3" flush valve have the ability to dump all of the water quickly, which is what pushes things out of the bowl.
  2. #107
    The Ultimate and the Ultramax use the same porcelain.
    The Ultramax was supposed to be their "HOTEL" version of the Ultimate. Toto figured the Ultimate worked plenty well enough for home use. I personally had one installed for two years, and it got heavy use with big crowds on weekends. It went two years before I needed a plunger, and then I didn't even know where to fine one.
    The Ultramax maintains a higher water level in the bowl, with the fill valve set higher and the higher overflow tube.
    Since the water leaves the tank quicker, TOTO used the red flapper with the hole in the lower portion to speed up the drop. It's rated at 1.6 gallons.
    The Ultimate, with the lower water level, needed the slower closing blue flapper that was plugged on the bottom, and because the water was slower to leave the tank, it still uses 1.6 gallons.
    If they only have the Ultimate, I wouldn't worry about it, they work fine. And if you think you really need more water, just hold the handle down a pause more.
    The Ultimate is a little quieter, since the water flows through slower. If the Ultramax had never come out, I would be selling plenty of Ultimates. But like anything in marketing, you can never be too quick, too large, or too new. Even if the old dog has been herding the sheep just fine the whole time.
  3. #108
    DIY Member Kimster's Avatar
    Jul 2010
    Manitoba
    Thanks for the info. I would think, then, if I get the Ultimate and I'm not happy with the flush or whatever, I can change out the fill valve, overflow tube and flapper myself and it becomes an Ultramax. I was thinking more about condensation on the tank. If the cold water mixes with room temp water in the tank -- less likely to sweat. And the more water left over in the tank after the flush, the less likely it will happen.
  4. #109
    Both tanks have water left over in the tank.
    I don't think condensation has ever been an issue.
    All toilets since 1992 use only a portion of the water in the tank.
  5. #110
    Jul 2010
    Manitoba
    OK, that's great, thank you.
  6. #111
    Comments by readers Reader Review's Avatar
    Jan 2006
    Hi Terry,
    I bought a Toto UltraMax at your suggestion. Love it.
    Now about to put in another toilet. The current toilet has a handle on the front. The Toto UltraMax wont work because the toilet must fit into a not wide space. The Toto UltraMax has the handle on the side and it would be hard to reach.
    I would like to stick with Toto and I saw the Toto Clayton on your website which has a handle on the front. It should fit and the handle would be easy to reach. Have you had any experience with the Toto Clayton? Hopefully, it behaves the same as the Toto UltraMax.
    Thanks in advance.
    Donald S
    Performance in the Clayton is also good
    Wish I lived in Seattle so I could come and see you guys. Thanks again.
    Donald
  7. #112
    Sounds like you don't have the minimum mandated space for the toilet (15" from the centerline). This could give you grief with the building inspectors. Some places require a permit to install a new toilet, some don't, and many ignore that fact. Some of the Totos can be ordered with the tank guts reversed...i.e., the handle on the right. This is true for at least some of them sold as ADA complient toilets where the handle is required to be on the door side of the stall (i.e., not stuck next to the wall).
  8. #113
    DIY Junior Member blackhawkfan's Avatar
    Sep 2010
    Boston MA
    I am in the market for a new, water-saving toilet. From this site it seems like the UltraMax is the way to go. I see on Toto's website that they have an UltraMax II with double cyclone flushing and 1.28 gpf. Does anyone have experience with this new system and the 1.28 gpf capacity? Does it clean the bowl and resist clogging? We have septic and three young kids so I am trying to use the least amount of water possible for savings and wear and tear while minimizing clogging, as kids can do.
    Thank you.
  9. #114
    Use the search function...you'll get lots of hits. While I can't comment on other brands, the Totos at 1.28g work as well as their 1.6g, older versions. The double cyclone makes eventual cleaning easier since there's no rim to hide crud, and it does wash the bowl. Just keep in mind that no low-flow toilet washes as well as the old ones that could use as much as 8g. Sanagloss also helps, as it is much smoother and things don't stick as well, which makes them wash off easier.
  10. #115
    DIY Junior Member NightowlDC's Avatar
    Sep 2010
    D.C.
    Default Will the Ultramax fit my space?
    I'm ready to buy the Ultramax to replace my current toilet, but after looking at the spec sheet, I'm worried it might not fit. My current toilet has a 12'' rough in, but it also sits four inches from the wall. According to the spec sheet for the Ultramax, it is supposed to sit less than an inch from the wall, which I can't do because I have cut-off valves on the floor between the wall and the toilet--see picture below. Will the Ultramax still fit? If not, can someone recommend a comparable toilet that will fit? Thank you!
  11. #116
    The rough-in is determined by measuring from the finished wall (not th ebaseboard unless it is very high) to the center of the toilet flange, which is normally also the bolts that hold the toilet to it. The important thing about the shutoff is how far offset from the centerline of the toilet is it. The space at the back of the toilet to the wall on the drawings is related to a standard rough-in. If the rough-in is not standard, then you either get a different toilet to match it, it won't fit, or you have a bigger space behind it than designed. Some (not all) toilets are available with 10, 12, or 14" rough-ins.
  12. #117
    Neither the Drake or the Ultramax will work if you have the shutoff behind the bowl and the wall like that.
    You will need to look at some small footprint bowls.
    The TOTO Aquia may work for that.
  13. #118
    DIY Junior Member kli's Avatar
    Sep 2010
    Hi - What great information! Thank you Terry. Terry's information over the years convinced us to purchase the Toto Ultramax. They are two years old now and one has developed a squeak on refilling. The annoying squeak lasts from a second to about 10 seconds. It doesn't appear to leak from the seal. I see the new fill valve is TSU18A. Do you think I need to replace it? Thanks in advance.
  14. #119
    I would first make sure that the shutoff at the wall is open all the way.
    If that is open, and it squeaks for that long, you may need replacement.
  15. #120
    Sep 2010
    D.C.
    Thank you very much for the advice; you saved me from buying toilet I'd have to return. The Aquia looks great (does it matter which version?), but the spec sheet for it doesn't seem to list the space between the wall and the back of toilet. Would it leave me with 3-4'' of open floor space? The valve above appears to be on the centerline of the toilet, so I'd need some open space there in the back of the Aquia. From the wall to the bolts on my current toilet is 12''.
  1. TOTO Neorest 500 toilet product review and comments. MS950CG
    By Terry in forum Toilet Forum discussions
    Last Post: 03-24-2014, 07:54 PM
  2. Toto Soiree or Guinevere review, installing, comments and pictures
    By Plunger in forum Toilet Forum discussions
    Last Post: 03-02-2014, 12:20 PM
  3. Toto Carlyle toilet Review, comments and pictures
    By Reader Review in forum Toilet Forum discussions
    Last Post: 06-22-2012, 04:07 AM
  4. TOTO Neorest 550 MS980CMG Dual Flush product review and comments
    Last Post: 07-20-2011, 10:09 AM
  5. Toto Dalton toilet review, owner comments and pictures
    By Perfectionist in forum Toilet Forum discussions
    Last Post: 03-30-2010, 11:34 AM
