Page 4 of 11 FirstFirst 1234567891011 LastLast
Results 46 to 60 of 164
Thread: Toto Ultramax product review, comments & pictures
  1. #46
    DIY Junior Member fish9483's Avatar
    Feb 2009
    Canada
    Default eco version
    how does the eco version compare and is there any that really work. thanks in advance
  2. #47
    The Eco Ultramax uses the same porcelain.
    They add a weight to the flapper to make it close quicker.
    If you need more water, a person can always hold the handle down just a bit longer.
    I've been using the Eco Gwyneth and the Eco Drake, they seem to work fine.
  3. #48
    Feb 2009
    Canada
    so you would recommend the Eco Gwyneth and the Eco Drake over the Eco Ultramax
  4. #49
    I didn't know I was being asked that.
    All of the Toto toilets are pretty similar.
    I prefer one-piece toilets.
    I try different toilets so I can answer questions from customers.
    The next one I'm putting in is the Toto Soiree.
    I've installed quite a few for others, and they like them so much, I want one too.
    By all means, get the Ultramax. I have one of those downstairs at the moment. I got mine with the Sanagloss.
  5. #50
    Default Aquia II vs ecoUltramax
    First of all - thanks for such a great forum. I had no idea how little I knew until I started reading your site.
    I need to buy 2 toilets and am completely torn between the Aquia II (CST416M) and the ecoUltramax (MS854114E). All of the reviews of the standard Ultramax make it seem like the best option overall......but I have not heard much about the ecoUltramax in comparison....and the few responses you gave to other questions about the ecoUltramax seemed to pale in comparison to your raves of the normal Ultramax.
    Leaving cost out of the equation, if you were to select one for your home, would you pick the Aquia II or the ecoUltramax? And for what reasons?
    Some of my concerns are:
    Which is easier to install? (sounds like the ultramax due to the unifit adapter of the Aquia which seems to make it a bit more tricky)
    Which has the better flushing capacity?
    Which has a better flushing mechanism (dual max vs emax)?
    Is the eMax flushing system about as good as the gmax system (as i assume the gmax is their top end system)
    Also, I have seen MAP ratings on this site for the Aquia II of 800 grams (I'm assuming tied to the 1.6gpf button), but nothing for the ecoUltramax. Do you know what the MAP rating is for the ecoUltramax?
    And does the 3" flush valve of the ecoUltramax make a big difference over the flush valve of the Aquia II?
    I may be renting my house out too, so want something that is rock solid and reliable since tenants aren't typically very careful about these things.
    Ok, I have already written far more than I should have.....but any feedback would be greatly appreciated.
  6. #51
    Apr 2007
    Ontario, Canada
    Quote Originally Posted by JakesWorld View Post
    Actually the CST416M has a Map test of 500 the old CST414 has a Map test of 800.
    I would put in the Ultramax over the Aquia.
    I like a One piece toilet over a two piece for cleaning purposes, plus One piece just seems more upscale compared to a two piece.
    Some people have proplems with the water surface of the Aquia.
    Aquia can be harder to install especially if you have tile floors and you have to drill and anchor the mounting blocks.
    The Aquia flush valve assembly is more complicated than the regular flush valve.
    The Ultramax (G-Max) has a Map test of 800 and the Eco-Ultramax (E-max) has a Map test of 500.
    There is no difference in price so unless your are concerned about the 1.6 compared to the 1.28 water use, i would put in the Ultramax.
  7. #52
    Default Thanks!
    Thanks so much for the feedback and advice. I really liked the comment about the eMax flushing system being less complicated than the dual flush.....I had not thought about that and seems like a really good point. As much as I admire the look of the Aquia (love the skirted and contemporary look) there seem to be several concessions to go that route (unconventional install, unconvential flush mechanism, etc). But they both seem great in their own ways.
    Thanks again everyone. I'll be sure to post some pics once I pull the trigger and get them installed!
  8. #53
    Feb 2009
    Canada
    my toilet drain is 12" centre to the wall. so the ultrax should just set in where the old one was?
  9. #54
    Apr 2007
    Ontario, Canada
    If you have 12" then yes it will fit no problem.
    That is a standard toilet rough-in.
  10. #55
    DIY Junior Member nanoec's Avatar
    Jan 2009
    California
    Default Eco Ultramax one-piece with Sanagloss
    I installed it a week ago and so far we are loving it. The installation was very easy. The one piece comes fully assembled so all you do is put it on the wax seal, tighten down the nuts on the closet bolts, connect the water supply, then put on the supplied seat and it is ready for action. The biggest challenge was the ca. 1948 closet drain, not the toilet itself. The 1-piece Ultramax looks great in our Eichler (modern style).
    So far the toilet has performed flawlessly. The flush is quiet by our standards. We have not had any issues with flushing...haven't needed a second one yet. I am happy with the water spot (which is why I steered away from the Aquia) and the Sanagloss has kept things clean. The only thing I am not 100% satisfied with is the comfort of the seat. Other than that it has been a great buy.
    Lastly, I want to thank everyone for all the posts as this site was instrumental in the background research I did which led to the selection. Keep up the good work!
  11. #56
    Default Eco Ultramax vs Ultrmax
    Hi,
    I am from Canada and I am interested in the non eco ultramax or drake models. The website that lists the Map ratings only covers the eco models from what I can tell.
    Here is the website.
    http://www.veritec.ca/mid.php?top=6&option=7&img=5
    Jason
  12. #57
    The MaP for the 1.6 Drake is 900 grams and the Ultramax being 700 grams.
    I used the 325 gram rated Ultimate for two years and it worked very well.
    In the same bathroom, I tried the Kohler Cimarron, and it plugged constantly.
    The guy that wrote the MaP testing finally bought himself a low flow toilet, the Carama with the 550 gram rating.
    I was never a fan of the Caroma and I told him so. He had to find out the hard way, that the Caroma bowls don't stay clean.
    Video here of the splashy Caroma
    http://video.google.ca/videoplay?docid=-1855798188535347905
  13. #58
    Comments by readers Reader Review's Avatar
    Jan 2006
    We love our TOTO and recommend you to everyone. Excellent customer service.
    Carol G
    Arlington WA
    Purchased in 2003
    A few years ago we bought a MS854114S G-Max Toto toilet from you.
  14. #59
    Jan 2006
    I would like to buy another Toto Ultramax, elongated, in cotton,
    Bart V
    Wenatchee WA
    Cotton White
  15. #60
    Jan 2006
    Hi Terry,
    This is a follow-up to our phone discussion at noon today. I am interested in purchasing another Toto Ultramax, elongated, cotton/white. I'll pick it up either this Thursday or Friday, and will call you first. Thanks.
    Gil H
    Bothell WA
  1. Toto Carlyle toilet Review, comments and pictures
    By Reader Review in forum Toilet Forum discussions
    Last Post: 06-22-2012, 04:07 AM
  2. TOTO Neorest 500 toilet product review and comments
    By Terry in forum Toilet Forum discussions
    Last Post: 12-27-2011, 04:28 PM
  3. Toto Soiree or Guinevere review, installing, comments and pictures
    By Plunger in forum Toilet Forum discussions
    Last Post: 09-12-2011, 02:22 PM
  4. TOTO Neorest 550 MS980CMG Dual Flush product review and comments
    Last Post: 07-20-2011, 10:09 AM
  5. Toto Dalton toilet review, owner comments and pictures
    By Perfectionist in forum Toilet Forum discussions
    Last Post: 03-30-2010, 11:34 AM
