Results 1 to 5 of 5
Thread: Help Identifying Hole Below Pilot Orifice
    DIY Senior Member molo's Avatar
    Sep 2006
    cold new york
    Default Help Identifying Hole Below Pilot Orifice
    Hello,
    I have an Empire gas heater (stand alone unit). There is an aluminum fitting that is about 1.5" below the real pilot orifice. There is a machine made (not corrosion made) hole in the fitting. The fitting is part of the pilot gas supply tube. This hole in this fitting is emitting gas and lighting (acting like a second pilot).
    Is this hole serving some purpose and why is it lighting? One theory I have is that not enough gas is getting to the real pilot orifice, but I still don't know the function of the opening.
    Thanks for any insight.
    "Any American who is prepared to run for President should automatically, by definition, be disqualified from ever doing so."
    Gore Vidal.
    Mar 2011
    Houston, TX
    Sounds like you are talking about the hole that adds the correct amount of air to get a clean flame.
    If it is burning from there then you may have a restriction in the pilot orifice.
    Sep 2006
    cold new york
    That sounds like a good possibility. Will the pilot need to be disassembled to be cleaned?
    Gore Vidal.
    DIY Senior Member dj2's Avatar
    Aug 2013
    California
    Before you rush to disassemble the pilot, I think you ought to call Empire and ask them this question.
    If you disassemble and then re-assemble the pilot assembly in order to clean the orifice, you may create a new problem of misalignment.
    Sep 2006
    cold new york
    Quote Originally Posted by dj2 View Post
    Yes, I decided not to disassemble it. I will talk to Empire about it.
    Gore Vidal.
  1. Question about 1 hole versus 2 hole kitchen faucets
    By Chuck Roy in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-23-2013, 06:51 AM
  2. pilot goes out with new thermocouple
    By ilya in forum Water Heater Forum, Tanks
    Last Post: 04-02-2011, 09:38 AM
  3. size hole for single hole faucet
    By bobbieK in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-14-2009, 01:31 PM
  4. Orifice in burner in American Water Heater
    By pmizell in forum Water Heater Forum, Tanks
    Last Post: 02-05-2009, 02:39 PM
  5. Gas boiler pilot light
    By pedietz in forum HVAC Heating & Cooling
    Last Post: 02-20-2007, 06:35 PM
