Results 1 to 2 of 2
Thread: Thermal Barrier at top of XPS wall.
    DIY Junior Member pex006's Avatar
    Jul 2012
    Pittsburgh, Pennsylvania
    Default Thermal Barrier at top of XPS wall.
    Hi I have 2 inch thick XPS panels on my basement wall. The faces are covered with a thermal barrier, but the the 2 inch thick top that is facing the floor joists is exposed. Does this have to covered with a thermal barrier and if so, how is it usually addressed?
    In the trades Dana's Avatar
    Jan 2009
    It's usual to L-over the top with a strip of rigid foam to the foundation sill, and up the band-joist to the subfloor (sealing the seams & edges with can-foam) with a continuous strip of foam insulation. Foundation sills & band joists are very often the single largest air leak in a house, far exceeding leakage at windows & doors(!), so sealing & insulating there is VERY worthwhile.
    If you do that, installing a minimum of 3" of rock wool batt insulation snugged up to the band joist foam and well fitted to the wood meets spec as a thermal barrier from a fire-code point of view on the foam. Unlike mid-density fiberglass, rock wool batts are sufficiently air retardent to not lose R to convection through the batt itself, but a snug fit at the edges matters. And unlike fiberglass leaving it exposed does not have a friable micro-fiber floating-in-air issue.
    Both of the major box-store chains carry R15 Roxul (3.5") these days. It's easy to trim to shape with a bread-knife.
  1. Do I need a vapor barrier?
    By Hockeylucky in forum Shower & bathtub Forum & Blog
    Last Post: 02-22-2013, 02:23 PM
  2. Vapor Barrier needed for basement bathroom wall?
    By mrmichaeljmoore in forum Remodel Forum & Blog
    Last Post: 03-22-2010, 03:13 PM
  3. Pex and the O2 barrier
    By franck@geneseo.net in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-08-2009, 06:29 AM
  4. Thermal Expantion Tank vs Thermal Expansion Relief Valve?
    By Grayfeathers in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-07-2009, 10:08 PM
  5. Vapor Barrier
    By nelsonba in forum Remodel Forum & Blog
    Last Post: 11-16-2007, 02:56 PM
