Page 2 of 2 FirstFirst 12
Results 16 to 17 of 17
Thread: Help Heatpump freezing
  1. #16
    Mar 2011
    Houston, TX
    Quote Originally Posted by nukeman View Post
    Just seeing if you ever figured this out...
    Would be nice to know what happened to repair it.
    The info you provided was good, It should be fixed by now.
    Just my opinion, That system should have shut down before icing up that way.
    Most systems look at High Pressure for safety cutoff, But if it is low on refrigerant it can run forever, and is very well Cooled.
    Hope to hear a report soon.
  2. #17
    Nov 2009
    VA
    Yeah. This is why I like some of the 'higher end" systems. They have more types of protection for the compressor. The problem is that most home owners don't know about these details. Best thing is try to get a system that meets your needs (SEER, 1 or 2 stage, etc.) and then look at the types of protection is has for the compressor and look at cost last. It might only be a slight bump in price to go from a base model unit to something that has better protection(such as high pressure, low pressure, and thermal limits). The next step up usually has a better SEER and other features as well.
    If you burn up the compressor (even if the part is under warranty), you still won't like the bill if you are paying for labor.
  1. Several questions about water heaters. Oil or heatpump?
    By fatdaddy in forum Water Heater Forum, Tanks
    Last Post: 09-23-2013, 02:47 PM
  2. Heatpump question - split system vs single
    By yds in forum HVAC Heating & Cooling
    Last Post: 03-29-2010, 07:05 PM
  3. Using springwater for heatpump source
    By Ridgeview Farm in forum HVAC Heating & Cooling
    Last Post: 02-22-2010, 12:36 PM
  4. Geothermal heatpump & re-circulation pump.
    By mlawrence in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-28-2008, 12:01 PM
  5. geothermal heatpump
    By chaddix in forum HVAC Heating & Cooling
    Last Post: 09-23-2007, 05:04 AM
