Page 2 of 2 FirstFirst 12
Results 16 to 16 of 16
Thread: water & growth on top of my water heater - replace or repair?
  1. #16
    In the trades Dana's Avatar
    Jan 2009
    You can insulate it, but not with a flammable insulation. Fiberglass or rock wool wrapped in high-temp foil tape would be fine, closed cell foam as depicted not so much.
    The gases in the vent stack under normal operation are well above the service temp of any closed cell pipe insulation, and under some conditions will exceed it's melting or kindling temperature (varies by polymer type.) The gases coming out of the water heater itself are even hotter, but diluted by the room air by the time it's in the vent piping, making the stack temp somewhat cooler. If the stack is blocked or backdrafting, you get the full blast of less-diluted exhaust pouring across the top of the tank.
    It's quite possible that it's venting properly when the water heater is firing, with the spillage onto the water heater occurring primarily when the other bigger-burner appliance is running. It's also possible that your house is tight enough that any time the clothes dryer and kitchen exhaust fans are running at the same time it back-drafts. Any time there is any suspicious symptom like what you see in the pictures it's worth testing it under different modes, but get it looking sorta-code-legal first: Replace the tee with a wye into the common flue, seal all seams & joints, peel back the insulation so that even if it backdrafts the hot gases won't be blowing directly onto the insulation.
  1. Water softener issue: Try to repair or replace?
    By Debthegardner in forum Water Softener Forum, problems, installation and reviews
    Last Post: 07-18-2013, 03:06 PM
  2. Should I repair or replace water heaters?
    By MEYLIN in forum Water Heater Forum, Tanks
    Last Post: 01-08-2013, 04:13 PM
  3. Electric hot water heater not working - repair or replace? Help!
    By aGrandma in forum Water Heater Forum, Tanks
    Last Post: 12-09-2010, 08:27 PM
  4. Replace or Repair Tank Water Heater
    By odyinpdx in forum Water Heater Forum, Tanks
    Last Post: 09-30-2009, 12:03 PM
  5. ice water box valve repair or replace
    By montreaux in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-17-2008, 08:02 AM
