Results 1 to 2 of 2
Thread: Thermostat for outdoor boiler
    DIY Junior Member Driftrocker's Avatar
    Oct 2013
    Minnesota
    Default Thermostat for outdoor boiler
    Hi I am trying to set up outdoor wood boiler to heat my garage with water to air heat exchanger in plenum of old General Electric forced air furnace. Problem is thermostat only has 2 wires and only two to furnace (no control board) don't want or need gas portion to work. Just want thermostat to kick fan on when temp is low and off when warm. This furnace only will kick fan on with gas when it is warm and fan goes off when gas valve closes and unit cools. So do I need to somehow bypass internal furnace thermal switches? And if so how?
    In the trades Dana's Avatar
    Jan 2009
    There isn't enough information to even begin to answer the question. A model number on the furnace would be the minimum starting point, which may (or may not) yield a web-searchable manual or schematic of it's controls.
  1. Boiler outdoor sensor placement
    By philtrap in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-21-2013, 03:58 PM
  2. Thermostat to control new Burnham Alpine 105 boiler
    By 2Bgreen in forum HVAC Heating & Cooling
    Last Post: 09-18-2012, 08:36 AM
  3. thermostat for second zone doesn't control boiler?
    By HerHandyMan in forum HVAC Heating & Cooling
    Last Post: 02-23-2012, 06:36 PM
  4. Replies: 0
    Last Post: 02-11-2012, 03:26 PM
  5. Boiler at a part time 2nd home & programable thermostat
    By pit monster in forum Boiler Forum
    Last Post: 12-29-2009, 04:19 PM
