Results 1 to 13 of 13
Thread: Luxaire Furnace
    Default Luxaire Furnace
    Just turned furnace on for the year for heat and it will not work. Worked fine at the end of winter. Cleaned the flame sensor as I do every year and nothing. Igniter will not glow. Any suggestions? Thanks
    Mar 2011
    Houston, TX
    Are you getting power ?
    Maybe a safety switch is not closed properly. Or your T-Stat is not calling for heat.
    Good Luck.
    DIY Senior Member dj2's Avatar
    Aug 2013
    California
    You need an accurate diagnosis, something that can't be done from here (in front of the computer).
    1. Gas supply: you mentioned 'flame', so you have a gas unit. Is gas on? Is gas reaching the gas valve? Is gas coming out of the gas valve? Is the orifice clean? - you need a plumber to check and repair gas valves (not a DIY project).
    2. The igniter could be out.
    This is a gas furnace. How do I check the spiral glow igniter?
    Mar 2011
    Houston, TX
    Quote Originally Posted by Fudog View Post
    With a OHM meter. After you turn power OFF.
    They are very fragile, do not touch it.
    If it is open the the gas valve will not turn on.
    Good Luck.
    What should i get for an ohm reading to determine a bad one?
    Took an Ohm reading and showing 284 and have 112v at the plug in.
    Mar 2011
    Houston, TX
    A bad one will be open.
    A good one will give you a reading on R X 100. Depends on the model.
    None of the rollout limit switches are tripped. There were 3 of them. All had 27-28 volts on each side.
    Induced draft blower is working. Would the spiral igniter have an ohm reading stamped on it? 284 is what i am showing.
    Mar 2011
    Houston, TX
    What is your model number ? The manual may tell you what the resistance should be.
    If it had 112V across it and it was not glowing then it is bad.
    The cold resistance sounds a bit high to me.
    Be careful playing with Gas.
    Had the HVAC Repairman come yesterday and everything checked out fine with the Diagnosis being [vent motor clogged up with stink bugs] We have had alot of them in WV and he said he had done the same thing the day before on another customers furnace. I guess since the weather has started to cool down the stink bugs are trying to get inside anywhere they can thru furnace vents and dryer vents. I just wanted to let everyone know what the diagnosis was and I appreciate the help as I wanted to fix this myself. I just came home from work. I drive Tractor trailer at night and it is time to sign off and go to bed. Thanks!
    Mar 2011
    Houston, TX
    Thanks for the report.
    Sounds like all safety systems were working.
    That is a good thing.
  1. What is this and what does it do for my NG furnace?
    By greaper in forum HVAC Heating & Cooling
    Last Post: 04-28-2013, 06:22 PM
  2. 60,000 vs 80,000 BTU furnace
    By CurbYourEnthusiasm in forum HVAC Heating & Cooling
    Last Post: 02-18-2013, 05:11 AM
  3. Conversion from gas furnace to electric furnace
    By debka in forum HVAC Heating & Cooling
    Last Post: 01-19-2013, 06:39 AM
  4. Luxaire Furnace
    By Fudog in forum HVAC Heating & Cooling
    Last Post: 04-29-2008, 06:50 AM
  5. What furnace should we get?
    By Sincraft in forum HVAC Heating & Cooling
    Last Post: 09-02-2007, 01:13 PM
