The submersible pump that I plan on using has a built in check valve.
The pump will be 100' deep; static water level at 50'.
I was planning on adding an additional check valve at the input to the pressure tank,
but I'm now wondering if I should put it instead right on the output of the pump.
What's the typical setup for check valves ?
Thanks,
Arky
Thanks,
Arky
