Results 1 to 4 of 4
Thread: Check valve location
    DIY Member Arky217's Avatar
    Jan 2008
    Arkansas
    Default Check valve location
    The submersible pump that I plan on using has a built in check valve.
    The pump will be 100' deep; static water level at 50'.
    I was planning on adding an additional check valve at the input to the pressure tank,
    but I'm now wondering if I should put it instead right on the output of the pump.
    What's the typical setup for check valves ?
    Thanks,
    Arky
    DIY Senior Member craigpump's Avatar
    Apr 2012
    ct
    Standard practice here in Ct is to have a check valve at the tank.
    Some states prohibit a check valve at the tank, check your state code.
    Jan 2008
    Arkansas
    Quote Originally Posted by craigpump View Post
    Well, I'm fairly remote back in the Arkansas hills, so a code doesn't apply in my case.
    I posted this question, however, before I noticed the sticky thread 'submersible pumps and multiple check valves'.
    From the advice in that thread, it would seem that if I put in another check valve in addition to the one built into the pump,
    that for my well (115 feet deep, 50 feet to static water level), I should put it right at the discharge of the pump.
    But, since i'm using a good quality (hopefully) pump (Gould, mod.#7GS05422C), perhaps I should just forget about
    adding another check valve.
    I'm kind of leaning in that direction now, since I've read the information in the above mentioned sticky thread.
    Anyone seem to think that not adding another check valve for my particular well and pump would be a mistake ?
    Thanks,
    Arky
    Moderator valveman's Avatar
    Mar 2006
    Lubbock, Texas
    Goulds should be putting good check valves on their pumps. Actually the check on the pump will stay closed better if it has all the pressure holding it down as compared to having another check anywhere else, which would take some or most of that pressure off the check at the bottom.
    Water hammer and slamming from repetitively cycling the pump on and off is what causes most check valves to fail. Because of this, many people just add one or more extra check valves for safety. Using a Cycle Stop Valve will eliminate the water hammer and repetitive cycling, which will make everything last longer, including the check valve, bladder in the tank, pressure switch, control box, and most importantly the pump/motor.
  1. a separate flow check valve or a circulator with a flow check valve?
    By diyfun in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-08-2012, 08:31 PM
  2. Swing Check vs. dual check vs. double check valve
    By colbymom in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-10-2011, 01:19 PM
  3. Replies: 5
    Last Post: 09-19-2010, 08:48 PM
  4. Chattering Square D pressure switch, and check valve location?
    By rstl99 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-29-2010, 09:10 AM
  5. Pressure Switch Chatter & Check Valve location
    By azapplewhite in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-23-2008, 02:52 PM
