Page 2 of 2 FirstFirst 12
Results 16 to 16 of 16
Thread: Drain leak at slab joint
  1. #16
    DIY Junior Member sdmark's Avatar
    Sep 2011
    San Diego, Calif.
    It's much better to not have that big of a gap between the pipes...
    I actually started with 3/8" but had to cut another 1/8" to let the thin stop get in between the pipes and get the pipes aligned ... so maybe my initial measurement was off, or it didn't go as far down into the bottom coupling as I thought it would.
    To get things to fit, you can loosen the reinforcement collar, slide it off, then you can deal with just the inner rubber...
    Exactly what I did. I didn't find it very easy since the bottom coupling was set in cement and the pipe just above the top coupling was vertically constrained by the Y (?) going through drywall. Basically I had to get a 10 1/2" pipe into a 10" almost-rigid gap.
  1. Compression joint leak
    By JAR8832 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-13-2012, 06:35 PM
  2. Slab floor drain leak
    By chas22 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-28-2009, 05:16 PM
  3. ABS joint leak
    By mattt19 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-18-2008, 05:46 AM
  4. Leak in drain, under slab
    By HDFAN1 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-06-2007, 10:56 PM
  5. Fixing a leak in an ABS drain pipe joint
    By Raymond Sukys in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-26-2007, 03:27 PM
