Results 1 to 5 of 5
Thread: Wall hung toilet gasket
    DIY Junior Member Peggins's Avatar
    Oct 2013
    Maine
    Default Wall hung toilet gasket
    I have a customer with an old Crane wall hung toilet that began to leak through the ceiling. It had a neoprene gasket and a lot of wax and had probably worked fine for decades. I've never had the joy of working on a wall hung toilet before but have heard that wax is a bad idea because it will eventually flow and leak. The problem is that when I re- installed the toilet with the only gasket (Zurn, 3/4 " thickness) I could get from my supplier it leaked. I cleaned everything very well and instructed the tenants to not use the toilet for 3 days, I know they complied. When I pulled the toilet again there was no glue on at least half of the flange, which I had applied liberally to the gasket as per the instructions. I had been a bit concerned about how far the gasket was recessed into the toilet so the second time around I measured. The flange of the carrier protrudes from the wall 1/8" and the gasket recedes into the toilet 1/4" . Bingo as to why I failed, and very glad I told them to wait on repairing the already badly damaged ceiling.
    I found a 1 1/4 Zurn gasket, with no glue, would that work?
    Can I simply use two 3/4" with glue between the two gaskets?
    Do new wall hung toilets have a smaller recess and therefore the 3/4 gasket would work fine?
    Clearly the old Crane is not low flow, if I sold them a new toilet what would you recommend?
    Thank you, I've been a lurker here for years and have learned a lot. Hoping you can help me solve this problem.
    1/8" from the wall is too short.
    Adjust waste horn to project 5/16" from
    finished wall.
    Glenwall instructions
    They do make a wall mount rated wax ring.
    We use the foam rubber washer, and we test them before we leave the job. Even with the glue.
    I used to work in a bicycle shop, and it looks like the same stuff I patched inner tubes with.
    Oatey reinforced wax ring spec
    http://www.oatey.com/doc/Urethane_Re...d_Wax_Ring.pdf
    We have been replacing with the American Standard Glenwall.
    Gerber now makes a replacement too in the Maxwell line.
    Oct 2013
    Maine
    Thanks for the fast reply. I tried to adjust the waste horn, but after years of sitting there it would not budge, so I'm stuck with the dimensions that currently exist.
    When re-hanging the bowl, it's easier if you thread the top cap nuts first. You can tighten three nuts down snug, the forth should be left hand tight. It's the forth nut that can crack a bowl.
    convention is that the two bottom and top left bolts are tightened, and top right one is hand snug. You do not have "glue" the gaskets in place. The weight of the toilet secures them, have enough depth so it compresses the gasket and makes a good seal.
  1. Need advice for wall hung toilet
    By MCEscher in forum Toilet Forum discussions
    Last Post: 03-26-2012, 05:58 PM
  2. Wall hung toilet
    By ressler in forum Toilet Forum discussions
    Last Post: 07-26-2007, 07:47 AM
  3. Wall hung Toilet problem
    By trioxin in forum Toilet Forum discussions
    Last Post: 03-28-2007, 08:25 AM
  4. Wall hung toilet needed
    By johnec12 in forum Toilet Forum discussions
    Last Post: 03-16-2007, 06:15 PM
  5. Wall hung toilet carriers
    By Cass in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-22-2006, 06:51 AM
