Thread: Copper DWV catalogue
    DIY Junior Member britkath's Avatar
    Oct 2013
    Louisiana
    Default Copper DWV catalogue
    Where can I get a copper DWV catalogue that shows dimensions of all fittings, up to at least the 4 inch size?
    DIY Member BillTheEngineer's Avatar
    Jan 2011
    Smithtown, NY
    There is no standard in fitting sizes, all manufacturers are slightly different. The only thing that is the common is the size of the pipe. Same goes for PVC and CI.
    Mueller has some drawings for fitting
    http://www.muellerindustries.com/bim
    Oct 2013
    Louisiana
    I was looking for something with dimensions, such as what is at http://www.nibco.com/Literature/# under copercat.pdf, but for larger sizes up to 4 inch.
  1. Is It Okay To Spray "Great Stuff Foam" Around Copper Pipe and Copper Fittings?
    By turbocruiser in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-01-2013, 09:34 PM
  2. Soldering.. copper to copper OR copper to brass.. which one?
    By lithnights in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-02-2010, 05:15 AM
  3. It's just not Copper
    By Cookie in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-22-2008, 07:48 PM
  4. How much PEX vs. Copper?
    By lenoxlover in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-17-2008, 07:16 AM
  5. Copper to PVC
    By mark1154 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-18-2008, 01:05 PM
