Results 1 to 9 of 9
Thread: How to replace a clawfoot tub faucet and waste and overflow
    Default How to replace a clawfoot tub faucet and waste and overflow
    Replacing an old clawfoot tub faucet and tub drain.
    This one below was a little old.
    The owner had picked up a new drain and new faucet with shutoffs at the floor.
    The first thing is to shut off the water to the home and remove the old one.
    This one had copper 1/2" Male adapters. Normally with older installs, you will find galvanized pipe nipples through the flooring.
    The slip joint nut is at floor level for the drain.
    Either tape or pipe dope the threads and tighten the new stops on. These supplies from Sign of the Crab came with rubber cone washers and friction rings.
    The threaded portion of the tub drain needs thread sealant before installaton.
    So unthread the ends, apply the thread sealant, and reassemble.
    New faucet installed. New faucets come with a tall spout that is higher than the top of the tub. This is new plumbing code. Well...........at least new since 1920
    All ready for a shower curtain
    Sprinkler Guy Wet_Boots's Avatar
    Mar 2007
    Metro NYC
    Does a "classic tub" install like this get a pass from complying with any anti-scald valve requirements?
    To make it code, you would have a tempering valve on the system.
    For this install, it could have been in the ceiling of the room below where the access panel was.he
    Some homes use a tankless set at 120, or have a tempering valve either at the tub, or for the entire home at the water heater.
    Jul 2009
    North Vancouver, BC
    Terry where did you get the shower curtain holder? Is that the old one buffed out and shined up?
    Looks awesome.
    The curtain holder came with the shower faucet. Sign of the Crab.
    It's a two man job for sure! My main worry was that we would trip over it and bend it in half.
    Mar 2007
    Metro NYC
    Thanks. That three-handle tub valve reminded me of a long ago practice of soaking in a bubble bath with the hot tap just cracked open to allow a trickle of hot water (probably very hot - it was long before anti-scald valves were marketed) to keep the feet comfy-cozy. I don't think codes allow for that any more
    Jul 2009
    North Vancouver, BC
    How much? Looks pricey!!!
    My favourite kind of fixture.
    Do they come in chrome plated brass?
    JW
    The design of the old faucet looks like it could have had "Fuller balls" in it, which would date it to the 1920's or so.
  1. Stumped - How to Replace Tub Waste/Overflow w/ Very Tight Clearance to I-Joist
    By m42stanle in forum Shower & bathtub Forum & Blog
    Last Post: 07-06-2012, 10:55 AM
  2. Another clawfoot faucet question
    By ChrisRice in forum Shower & bathtub Forum & Blog
    Last Post: 10-02-2010, 08:27 AM
  3. Quality of decorative supply lines and drain/overflow for clawfoot tubs?
    By pmoe in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-09-2009, 01:35 PM
  4. Waste Drain assembly for Clawfoot Tub
    By Lina in forum Shower & bathtub Forum & Blog
    Last Post: 11-21-2008, 12:55 PM
  5. Waste and overflow
    By pchiker in forum Shower & bathtub Forum & Blog
    Last Post: 05-14-2006, 07:36 AM
