Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
Thread: Water surging and Water Pump Control Relay Short cycling
  1. #16
    Sep 2013
    I suggest you post a photo. Does your tank look like one of these? http://www.wellmate.com/
    A pressure tank normally has only one water pipe connection, although that connection is often via a tee.
    Also, you say that the water pressure is 60+. Is it still that high when the pump turns on?
    If you turn the pump off, and then open a faucet, how about much water comes out of the tap before the pressure tank is down to 30 PSI or lower?
    Edit: On http://www.wellmate.com/en-US/produc...onnect-series/ I see this which seems to match the descripton:
    So that is a contact tank rather than a pressure tank. If that is what the OP describes, he must have a pressure tank somewhere else.
  2. #17
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by craigpump View Post
    The give away is the large nut on top of the tank. He has a Well Mate with a verticle air volume control..
    I have one of those. When the AVC fails, it fails in one of two ways, either it stops letting air out, or lets out too much of the air, if it lets out too much air, then it also leaks water out the vent. Water leaking from the vent should not go unnoticed but the OP made no mention of that.
    The position of the AVC inside the tank is about two thirds of the way down, so it cannot let all the air out. The only plausible explanation is that someone plugged the vent because water was leaking out and then over time the air got absorbed, waterlogging the tank. For that to happen, the airmaker would also have to fail or be disabled. Granted, that too happens whet people put a valve cap on the snifter.
    The big nut could also be where the replaceable bladder is inserted.
  3. #18
    DIY Senior Member craigpump's Avatar
    Apr 2012
    ct
    Ever try to change one of those "replaceable" bladders?
    It's easier to change the tank
  4. #19
    Mar 2011
    Houston, TX
    LOL.
    KY Jelly works wonders.
  5. #20
    Feb 2011
    NW Ontario, Canada
    LOL Never underestimate the frugality of a Yankee!
  1. Jet pump rapid short cycling at cut-out
    By FRS in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-19-2013, 12:49 PM
  2. Pump short cycling I think?
    By Rod M1 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-01-2011, 09:06 AM
  3. Well pump short cycling
    By Eilselc in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-22-2011, 08:46 AM
  4. Pump is short cycling.....Very short!!
    By crittercatcher in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-29-2009, 09:26 AM
  5. Pump Control Relay
    By garcanser in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-15-2007, 08:30 PM
