Results 1 to 2 of 2
Thread: Need help with plumbing for new shower into ejector tank
    DIY Junior Member webuser1200's Avatar
    Oct 2013
    New York
    Default Need help with plumbing for new shower into ejector tank
    History:
    I have an existing half bath in basement and I'm moving the vanity and adding a shower. There already was an ejector pump. I did the following:
    1. Broke up the concrete
    1. Made a 2" whole into the ejector tank and put in the pvc pipe which connects to the shower drain. The shower drain is vented and the vanity connects into the shower drain and is also vented.
    My problem is that I made the hole into the side of the ejector tank too high. So on the other end the pvc for the shower drain is only a couple of inches below the top of the concrete. I have to get a in slab inspection before I can pore the concrete. So here are my questions:
    1. I looked at the plumbing code used by my town (https://law.resource.org/pub/us/code...c.ipc.2003.pdf) and I dont' see anything mentioned about how the pvc pipe needs to be laid out below the concrete. Is there a building code which dictates how much below the concrete the pvc pipe needs to be? can the pvc pipe be in concrete? Does it need to be wrapped up in something?
    Can I use the sand that I dug out to fill in below the pvc pipe? If the pvc pipe cannot touch the concrete what do I put on top between the concrete and the pvc pipe.
    Actually, unless you used some kind of "bulkhead fitting" to make the hole, you should not even put the PVC into the tank, regardless of how high it is. And, since you appear to have done that, I wonder if the rest of the piping is done correctly. Inspectors typically will reject the pipe in the concrete because it creates a weak spot which WILL crack at the pipe.
  1. Need advice on plumbing new pressure tank.
    By ZoneIII in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-15-2012, 01:13 PM
  2. Plumbing for ejector pump discharge-
    By cacher_chick in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-24-2010, 03:24 PM
  3. Plumbing Solar Storage Tank
    By ARSolar in forum Solar and Geothermal Water Heating Forum
    Last Post: 10-02-2009, 09:16 PM
  4. Ejector pit plumbing
    By alphadog00 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-20-2007, 07:33 PM
  5. Replacing plumbing at well supply tank
    By JON in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-11-2005, 02:40 PM
