Page 2 of 6 FirstFirst 123456 LastLast
Results 16 to 30 of 79
Thread: Inspection Check List for Kerdi Shower Builds
  1. #16
    Jul 2009
    North Vancouver, BC
    Default Kerdi Steam Shower Specifications
    Posts removed by John Whipple
  2. #17
    Jul 2009
    North Vancouver, BC
    Default Kerdi Check List: Removing humps in the pre-slope
  3. #18
    Jul 2009
    North Vancouver, BC
    Default Kerdi Checklist - How the tile is installed
  4. #19
    Jul 2009
    North Vancouver, BC
    Default How to do a pull check while installing Kerdi or Kerdi DS - Inspecting coverage
  5. #20
    Jul 2009
    North Vancouver, BC
    Default Inspecting for Hole in a Kerdi Shower's liner - And how to fix one if you find it.
  6. #21
    Jul 2009
    North Vancouver, BC
    Default Inspection Check List : Expansion - Do you have room for your tile assembly to move?
  7. #22
    Jul 2009
    North Vancouver, BC
    Default Requires Stone Inspections: Kerdi Shower Build
  8. #23
    Jul 2009
    North Vancouver, BC
    Default Shower Inspections: Kerdi Inside Corner Detail Options
  9. #24
    Jul 2009
    North Vancouver, BC
    Default Inspection Check List: Temporary Dam for Water or Leak Test
  10. #25
    Jul 2009
    North Vancouver, BC
    Default Kerdi Check List: Making sure there is an evaporation control for the water test
  11. #26
    Jul 2009
    North Vancouver, BC
    Default Kerdi Check List: Wall Framing Inspections - "Criss Cross Apple Sauce"
  12. #27
    Jul 2009
    North Vancouver, BC
    Default Inspection List for Kerdi DS Steam Shower Windows
  13. #28
    Jul 2009
    North Vancouver, BC
    Default Kerdi Inspection Check List: Checking the Shower's Grading
  14. #29
    Jul 2009
    North Vancouver, BC
    Default Inspecting the showers framing and blocking prior to installing Kerdi Shower Pan
  15. #30
    Jul 2009
    North Vancouver, BC
    Default Photos of Kerdi DS Flood Test Inspection - Control Dish and Tipped Coin Set Ups.
  1. Another Kerdi Shower Question or two...
    By Lunker68 in forum Shower & bathtub Forum & Blog
    Last Post: 01-18-2013, 01:16 PM
  2. Can I Use Any Thin Set With Kerdi? The ICC-ES Evaluation Report On Kerdi Says You Can
    By johnfrwhipple in forum Shower & bathtub Forum & Blog
    Last Post: 01-08-2012, 10:19 AM
  3. Shallow well jet-pump won't cut-out; builds to 48psi, cut-off set to 50psi
    By ladyD in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-30-2011, 10:41 AM
  4. Craigs List-Check this BOZO out.
    By nhmaster in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-08-2009, 01:05 PM
  5. Pressure builds up with Thermal Expansion Tank
    By gplumb in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-28-2007, 03:34 PM
