Page 1 of 4 1234 LastLast
Results 1 to 15 of 52
Thread: Need help with Fleck 7000SXT programming
    DIY Junior Member JimmyG's Avatar
    Sep 2013
    Florida
    Default Need help with Fleck 7000SXT programming
    I recently purchased a 48K, 1.5 cu ft Fleck 7000SXT water softener to replace my old kenmoore system that finally died, after 8 years. I've programmed it myself from what I learned on this forum but i'm not getting the water as soft as it was before. When showing the water is mostly soft but I can still feel some hardness in the water. I'm sure this softener should works better than my old one.
    I've tested the water at the well and it has a hardness of 20 grains with 3 grains of iron. I tested the water inside the house and it was a hardness of about 3 grains. I'm not sure if it should be zero or if 3 is normal. There are 2 people living in the house and use about 180 gal/day. I started with 6 lbs of salt per cu ft of resin, 9 lbs total, and have slowly increased it to 15 lbs per cu ft, or 21 lbs total.
    The DLFC is 2.4 gpm and the BLFC is .125 gpm.
    The settings are as follow:
    Capacity = 36,000
    Hardness = 30
    RS = SF
    SF = 20
    DO = 7
    B1 = 10
    BD = 65
    B2 = 10
    RR = 10
    BF = 60
    I would like it to regenerate every 7 days.
    I would appreciate any help and advice you guy's can give. Thanks
    DIY Senior Member Reach4's Avatar
    Sep 2013
    Non pro. Took a look at the manual, and here are some comments... probably not useful.
    Dropping to 3 grains from 20 is not so good in my opinion. Is that sample from cold water, or from hot which might have sat in the tank for a while after you added the softener? I test 1 or less on harder water than you on what seems like a very old softener.
    I think you are setting this to regen every 7 days, or sooner if you have a lot of use. There are diagnostics like HR Hours in Service since the last regeneration cycle. VU is volume used since last regen. I presume that is gallons, but their example of 25,000 seems very high.
    Are you sampling the day after a regen, or the day before a regen,.
    Is about 7 pounds of salt disappearing from the brine tank each regen? I bring that up in case you have a salt bridge or some other thing limiting the brine flow.
    Jan 2012
    California
    3 grains or iron? Do you mean 3 PPM of iron? If so, each ppm of iron should be compensated at 5 grains, so you would add 15 grains to your actual hardness. And you should use a high salt setting, 10+ pounds per cu.ft. and I would recommend using iron out salt or a regular cleaning of the resin bed should be done. Or... get an iron removal system ahead of the softener.
    JimmyG, you should click on the link in my signature. Actually ya shoulda done it before buying the new softener because you are going to get terrible salt efficiency with a 1.5'. And understand that most here do not have much experience in removing iron with a softener and would rather have people buy an iron filter and a softener. Use 4 gpg per ppm of iron and 3000 grains per lb of salt to calculate the K of capacity/gallons between regenerations and use regular solar salt. Then every 6 weeks do a manual regeneration after mixing a 1/4 cup of Iron Out in a couple gallons of water and pour it into the water in the brine well in the salt tank and your softener will do a fine job removing your 3 ppm of iron. You can buy 5 lbs IIRC of Iron Out or Super IO at most grocery or big box stores. It is a much better way to keep all parts of the softener iron free and overall it costs less than the IO salt.
    Nov 2010
    Maine
    Most of us here have a whole lot of experience using a softener to remove iron which is why most of us don't recommend using a softener to remove iron. However, Iron or not, your salt efficiency and water efficiency is going to suck big time.
    Jan 2012
    California
    Wow, we have no experience removing iron with a softener???? LOL. Like Tom said, because we do have real world experience and knowledge and training and certifications and education and we can use a calculator and common sense is why we dont recommend a softener for higher levels of iron removal. In theory, you could do 20 PPM iron with a softener, but that would not be a wise design choice. Your system is undersized for this application. Some people on this forum have no considerations for the environmental impact water softeners can have especially on inland water supplies. It is true that a single residentail application has almost ne real world impact, but commercial users of softeners, and large amounts of residential users do have an impact on the water supplies. Using a softener for iron removal is one of the most inefficient ways to treat iron. It is also fairly cheap since you already have a softener, it can do double duty.
    So, is your iron 3 ppm?
    Sep 2013
    Florida
    Yes the iron is 3 ppm. I didn't realize iron made that much difference in the hardness. So I need to look at getting an iron removal system?
    Sep 2013
    While you are at it, how is your sulfur or manganese? You can do more than one at once if you have those.
    Nov 2010
    Maine
    Quote Originally Posted by Reach4 View Post
    I see two choices. You can treat your iron with a separate filter which is what I recommend although it is the more expensive option. Option two would be to increase the amount of resin which will increase your capacity. The 7000 valve will be fine, you just need to change the tank and resin. The third option is too use a lot of salt and water.
    Sep 2013
    Florida
    I haven't checked it but I know the sulfur is high. Without the softener you can smell and taste it. Does that add to the water hardness?
    Sep 2013
    I like this for iron and sulfur. It would go right after your expansion tank and before your water softener.
    http://www.discountwatersofteners.co...ubic-foot.html It uses Centaur Carbon. I have one. They have a bigger and smaller offering also. Other people sell this technology too. This is not to say that your water is like mine. Yes, it is like buying another water softener. :-(
    I don't know about hardness from sulfur, but there is more to water than softness. Getting rid of sulfur and iron does make things smell better and stop red stains and black water.
    Softeners do not remove or reduce H2S (sulfur), or other gases/odors.
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    Quote Originally Posted by JimmyG View Post
    If the smell goes away when the softener is working, then most likely the smell is due to the iron. With high iron, I tell people that want to only use a softener to remove it, "You can move a ton of material with a half ton truck, but how long will the truck last doing it"?
    JimmyG, The ppm of iron is not all that much iron unless you are comparing to no iron 'city' water. And your 3 * 4 = 12 gpg compensated hardness + your 20 gpg of hardness is not going to cause your softener to be less efficient than if you had 32 gpg of hardness and no iron. The only difference is that you would have to use a resin cleaner like Iron Out periodically or eventually the iron will foul the resin, that will reduce the capacity and that would allow hard water through before regeneration and you'll be changing things so as to regenerate sooner and sooner until you fix the problem (replace the resin).
    You bought an undersized softener for your water usage and 32 gpg compensated hardness. I didn't do the math but it may be too small for great salt and water efficiency for your water use and 20 gpg. So, based on that and that you say there is H2S gas... I say you need a backwashed filter that will remove iron and H2S, IF you really have H2S. You may not and you may have IRB (iron or other reducing bacteria that cause odor) and then you need a disinfectant like chlorine and a backwashed filter to remove it and sediment caused by oxidation of the bacteria and iron. That all goes before the softener. As part of a system like that you'd have to have a correctly sized retention tank also.
    Is this H2S odor in both hot and cold water or one or the other? If it is in the hot only, you have a bacteria problem, not H2S gas, and as mentioned, if the odor goes away after the softener, you are confusing iron with H2S or other odor. If it is in the hot only, raising the temp on the water heater to 140f for an hour or two kills the bacteria for a time and then it comes back (that can be days to normally weeks) and you do it again.
    Sep 2013
    Florida
    Quote Originally Posted by mialynette2003 View Post
    I see you are in Ocala. Do you work for a water softener company?
  1. Fleck 5600SXT vs Fleck 7000SXT
    By amateurplumber1 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 04-02-2013, 11:38 AM
  2. Need help in programming Fleck 7000sxt.
    By clanmcclellan in forum Water Softener Forum, problems, installation and reviews
    Last Post: 01-14-2013, 07:52 PM
  3. Fleck 7000SXT 32k Noise Troubleshooting and Programming
    By kaisersoze in forum Water Softener Forum, problems, installation and reviews
    Last Post: 08-31-2012, 11:09 AM
  4. My new Fleck 7000sxt
    By fdny37 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 07-30-2012, 11:24 AM
  5. Programming 7000SXT
    By David58 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 05-06-2011, 08:26 AM
