Results 1 to 2 of 2
Thread: Soil stack and venting
    DIY Junior Member Tylock's Avatar
    Oct 2013
    Pittsburgh, Pa.
    Default Soil stack and venting
    Hello, I have an old rental and the soil stack stops at the first floor bathroom with a toilet on top of it which can't be moved. I replaced the old toilet in the basement plus added a wash basin. So those openings that were unintended vents are no longer and nothing worked, total vacuum. I snaked out the trap vent outside that was clogged and installed vents on the three sink traps. Everything works, but not great. There is a 5 inch iron pipe outside that comes out of the ground. It's to the side of the toilet in the basement 3 to 4 feet away. This pipe runs up the side of the house 30 plus feet and ends 3 feet above the gutter. Nothing is connected to this pipe on the exterior of the house. Do you think this is connected to the waste pipe underground? I plan on cutting it down in pieces for scrap then run a snake through it. If this is the vent and it dose work do I have to run a PVC pipe back up past the roof? What do you think?
    Thank you.
    I think your description is too convoluted to figure out what is happening, but the pipe outside, if it is a vent, is useless as far as your indoor piping is concerned.
  1. Connecting to a soil stack
    By lanthoma in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-15-2010, 02:56 PM
  2. Soil stack size
    By KLB in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-29-2008, 10:17 AM
  3. Soil Stack Question
    By Glimmerman in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-22-2007, 03:21 PM
  4. Soil Stack Horizontal Venting
    By wendelboec in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-20-2006, 02:42 PM
  5. Wet vent vs. soil stack?
    By Hazel in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-04-2006, 09:06 AM
