Results 1 to 14 of 14
Thread: question on wifi usage
    DIY Member u.s.coins's Avatar
    Mar 2012
    Pennsylvania
    Default question on wifi usage
    I have a lap-top windows-7 and want to use it in a waiting room that offers free wifi. would I be able to use my computer there and what do I do to connect, if it's a possibility? I need the how to spelled out so that a challenged operator like me can thoroughly understand. appreciate any help. thanks in advance.
    Mar 2011
    Houston, TX
    If you have your wifi adapter switch Off then turn it On, You should see a message saying new wireless network in range, or something to that affect, on the bottom right of your screen.
    Click on the icon and then click connect.
    If it is open access you can connect, But you may be prompted for a Network Key, that they can give you.
    Networks like that are normally not very secure.
    DIY Junior Member Recon0321's Avatar
    Oct 2013
    Arizona
    Some establishments require you to log in with a predetermined 64/128 WEP Encryption key. Some are also moving to WPA which is more secure. If you are in a establishment that has an open network, you can connect automatically, however as Rocket Scientist stated these are unprotected networks. Although these networks are behind a firewall, you data could be compromised. Protecting your computer with a firewall intrusion program is recommended which some high end antiviruses now have.
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by Recon0321 View Post
    While a firewall can protect data residing on a laptop, it would do little to protect data that has crossed the firewall onto the open public Wi-Fi.
    An open network can easily be compromised with Man-in-the-Middle (MitM) attacks. Essentially someone could be sitting out in the parking lot with a laptop, intercepting you and stealing what he can. MitM attacks can be perpetrated on secure wireless networks too, but in that case the attacker needs the security key. A VPN service is probably your best defense against MitM attacks.
    Feb 2011
    NW Ontario, Canada
    I work in IT and specialize in networking that includes security. A decade ago, I set out to prove to our CIO that our network at the time was not secure. We intercepted the CIO's network traffic and got his password. One thing to consider is that lots of folk will use the same password on multiple systems, so once you have it, Bob's your uncle.
    Mar 2011
    Houston, TX
    And to add, the security key is being broadcast and can be hacked.
    Port blocking is a good thing.
    And never use a website that requires a secure password.
    Cell Phones are fun to hack, and you can get a lot of experience. lol
    DIY scratch-pad engineer leejosepho's Avatar
    Nov 2006
    Three or four years ago in an out-of-town motel, I discovered someone was browsing my Win7 notebook while looking for whatever. So whatever you do, at least be sure to turn off your file sharing options.
    "Great minds discuss ideas, average minds discuss events and small minds discuss people." --Eleanor Roosevelt
    DIY Senior Member Murphy625's Avatar
    Jul 2013
    Michigan
    No problem using an open wifi network.. Just be sure you have a software firewall installed on your own computer and do not log into anything that requires your personal username or password.
    Nov 2006
    Quote Originally Posted by Murphy625 View Post
    ...do not log into anything that requires your personal username or password.
    I have heard that is not a problem as long as you only use copy-and-paste to log in. Problems can come when you type your credentials and some kind of keylogger is running.
    use tp link wifi router.
    Mar 2011
    Houston, TX
    Quote Originally Posted by julie cristal View Post
    What Model would you recommend ?
    Mar 2011
    Houston, TX
    Quote Originally Posted by leejosepho View Post
    Depending on the website, some HTTPS sites will not let you copy and paste passwords.
    It is easier to get the contents of your Clipboard, than to get to your keyboard buffer.
    Feb 2011
    NW Ontario, Canada
    ...some kind of keylogger is running.
    LOL
    If you have a keylogger installed, you already have bigger problems than worrying about using Wi-Fi.
    Mar 2011
    Houston, TX
    LOL
    Very True.
  1. Honeywell WiFi Thermostat install help
    By I26 in forum HVAC Heating & Cooling
    Last Post: 07-29-2013, 12:01 PM
  2. Mits 2 zone split - want wifi thermostat
    By rockycmt in forum HVAC Heating & Cooling
    Last Post: 04-25-2013, 01:50 PM
  3. WIFI thermostat - inexpensive solution for remote control
    By JerryR in forum HVAC Heating & Cooling
    Last Post: 10-29-2012, 06:06 PM
  4. Shower heads, water pressure and usage Question
    By spedprof in forum Shower & bathtub Forum & Blog
    Last Post: 07-21-2010, 10:11 AM
  5. sewage ejector load/max usage question
    By plumbbob in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-28-2005, 10:36 PM
